-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Can't hold boost!!! (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/301572-cant-hold-boost.html)
thelza23 Oct 14, 2007 09:01 PM
Can't hold boost!!!
I have so much tapering and was just wondering what I could do to remedy this? Mods are in my sig. http://i231.photobucket.com/albums/e...3/DSC00904.jpg
hksevoix Oct 14, 2007 09:04 PM
boost leak
Warrtalon Oct 14, 2007 09:08 PM
- The stock turbo tapers
- The more boost you run, the more it tapers
- The higher altitude you're at, the more it tapers
- IXs tend to taper a bit more due to the MIVEC as well
- NEVER make a post about boost before doing a boost leak test
thelza23 Oct 14, 2007 09:13 PM
There is no boost leak, had it checked already. I've seen other members with stock turbo hold the boost better.
Warrtalon Oct 14, 2007 09:15 PM
Had it checked by whom, with what tools, and to what boost level?
You've seen other members hold it better? What setup, how much boost, what altitude, what method of logging, what altitude, and what mods?
Evo_Jay Oct 14, 2007 09:20 PM
use ecu controlled boost or a EBC to customize your boost curve, but even though the stock IX turbo will usually taper to about 19-20, which is about where you at. You can get the turbo to hold 22 at redline, but thats really pushing it out of its efficiency range.
thelza23 Oct 14, 2007 09:22 PM
I work at a dealership and had one of the service tech check for me. As far as which member I dont remember exactly, just remember seeing it while searching...
thelza23 Oct 14, 2007 09:31 PM
So this is normal? cant do anything to help besides upgrading turbo huh?
