How is everyone's boost guage working?
Maybe i shouldn't of ran the split at the fuel pressure regulator :dunno: Boost guages sometimes reads zero during hard runs. Any ideas? Defective? It's the mitsubishi factory guage.
Where is everyone plugging thier boost hose from the guages into? |
Into the line leading into the blow off valve.
Originally posted by Fireball Into the line leading into the blow off valve. |
I looked at the directions in the gauge pack while I was at the dealer, problem is they tell you to tie into a vacume canister that is not on the car, at least it's not on mycar and I pointed that out to the regional rep.
I know some folks are tying in there (line running to the fpr) and I did as well. But I had my first stalling incident the day after installing the gauge. I spoke to the regional parts/service manager and he said there was a solenoid or valve in/near that line and that was not a good place to hook it up. If you notice, there is a second or so delay after cranking the engine before you get a reading from that location (line running to the fpr) which confirms that there is some sort of valve on that vacume circuit. Plus if you spring a leak on the line with it tied in there the fpr will see less boost/vacume than there actually is..... could be a very bad thing I moved it to the line that routes over the valve cover via the hard pipe on the driver side (had to drill a hole in the firewall though as the line was not long enough to use the factory gromet on the pass side firewall. I think the line I used after does run to the boost control solenoid. And it would still be bad to spring a leak there as you could over boost. |
thats odd...make sure it is hooked up correctly
Originally posted by mad_VIII ...I moved it to the line that routes over the valve cover via the hard pipe on the driver side (had to drill a hole in the firewall though as the line was not long enough to use the factory gromet on the pass side firewall. I think the line I used after does run to the boost control solenoid. And it would still be bad to spring a leak there as you could over boost. |
FPR line is fine as long as you are in between the solenoid and the intake and not the FPR and solenoid.
Downside to BOV is if it causes a leak the BOV won't open. :crap: If the FPR comes loose you'll end up with more pressure generally. |
| All times are GMT -7. The time now is 11:11 AM. |
