RPM's UP
ok so this has just gotten worse for my evo...i got an evo 9..now i know the clutch is on its way out..but for soem reason if i hit boost and bring the rpms up to like 4500 or more and push the clutch in....the rpms...dont really come down...it makes a sound as if i have my foot on the gas....and if i dont push the clutch in...the car will not engine break it feels as if i floor it through the gear and it feels like its in nuetral or soimething when i let off.....is it the clutch...what could this be
please guys i need some help
this has been discussed before it's an ecu issue with rev hanging
the cars been tuned once though even though the tune is off
Look up throttle hang.
anyone else
id say that it is throttle hang
if its ECU controlled throttle hang - the engine will start braking, and the rpms will drop normally, right when you disengage the top clutch switch.
you just press the clutch enough to hit the switch, but leave the clutch engaged. i think i only need to depress mine 1/5" to get it to start engine braking. |
What dex said
my friend had a problem like this with a stock MR when his clutch was bad so he replaced it and it was all good again so id go with replacing the clutch than see where ur standing
well my clutch is on its way out, even though it is not slipping, i can feel that its just about there. It may actually be the clutch so after i fix this i guess ill let u guys know
| All times are GMT -7. The time now is 08:54 AM. |
