How much boost can a stock evo 8 can handle?
Hi,
I have set mine up at 1.53bar (around 22psi) and there seem to be no problem. what's the boost level that stock evo8 can handle? I'm running on 98 octane |
What mods... are you tuned, stand alone, what year, stock internals.... come on man give us something to work with.
Originally Posted by s2krn
(Post 5134998)
Depends on Mods, Octane Gas, Tune...
why are there a bunch of these max boost topics?
and no one ever gives any information in them |
Originally Posted by evo86
(Post 5134981)
Hi,
I have set mine up at 1.53bar (around 22psi) and there seem to be no problem. what's the boost level that stock evo8 can handle? I'm running on 98 octane Much metric boost gauges go 1.5, 1.6, 1.7, 1.8, 1.9, then 2 bar. Double check that cause you may be running 1.8 bar which is ~26psi. |
Originally Posted by EvoJoeIX
(Post 5135395)
about 53psi. But you will have danger to teh manifold. Make sure you upgrade your egr also, they have a tendency to explode!
Stock internals are only rated to 450 at the crank.... be carefull
Originally Posted by scoob2evo
(Post 5136070)
more than you can afford pal
So what is the stock max boost for a 2003 Evo 8, with no mods?
Coz I'm reading off an electronic gauge, 1.53bar is correct.
It currently has BOV and HKS filter running on 98 octane. Since stock evo is 19psi (1.31bar), I'm just thinking how much boost evo can handle without further mod. 1.53bar seems to be running fine but you reckon I could go abit higher? |
Originally Posted by Eric Keely
(Post 5136160)
(Post 5134981)
Hi,
I have set mine up at 1.53bar (around 22psi) and there seem to be no problem. what's the boost level that stock evo8 can handle? I'm running on 98 octane also, when you run higher octane gas then your car was tuned for it's pretty much going to do nothing. |
