Would it be possible to use a 4b11 engine head on a 4g63?
why? what's the reasoning behind it?
Mivec.
It may very well be, but I would really have my doubts. But with enough fabrication, anything is possible.
Originally Posted by Jameson_IXMR
(Post 5201748)
Originally Posted by chrsevx
(Post 5204474)
Man, I hope it will be easy to do and cheap the additional help of mivec on a turbo would be insane for spool up.
you have a better chance in getting the evo 9 head on an evo8 block then u do with that junk that comes on the X to fit onto the evo8 |
yea but IX has mivec only on the intake side
well the 4b11 if im not mistaken uses a timing chain and not belt so clearance is diffenent
Is everyone forgetting the fact that the turbo now sits between the firewall and motor? A lot more work than just swapping the head since the cams and tranny sit the same way as previous evo's. Just my 2cents....
(Post 5201743)
Mivec.
(Post 5204474)
Isnt the 4B a Chrysler motor as opposed to a true blue 4G Mitsu Powerplant?
Krazy srt4,
you are correct the X uses a timing chain I don't know why some people waste our time with a stupid question like this. If you want intake and exhaust MIVEC then buy an Evo X. This idea is insane and would cost more money than it is worth. If you have that kind of money put it tward somingthing more useful that will make you more power. If you want more spool build a stroker. |
the 4b i think may be a chrysler motor
all-alloy straight-4 engines built at Mitsubishi's Japanese "World Engine" powertrain plant in Shiga on the basis of the Global Engine Manufacturing Alliance (GEMA)
