Cant boost past 10psi
i can floor it, but it only goes a bit over 10psi but wont go near 11psi.. this only started a week ago, boost was fine before that, i know the answer is boost leak test, but i just wanted to know if it could be anything else that might be common. my car has 23,000 miles on it. could it be bad spark plugs or something like that? i ordered WORKS Aperture High Pressure Shaft Seals just to have them in case the oem is leaking.. also if it was a boost leak, should i not be able to reach 4krpm? because its hard to hit 4k rpm right now with my boost not going past 10psi.. in 2nd and 3rd gear. havent tested 4th or 5th.
well technically you should reach any rpm without hitting "boost" persay....is it making any audible noises or its just hittin 11psi and driving normal....
i believe thats WG stock pressure....have you recently connected a MBC? EBC??? have you checked the hoses make sure nothing came loose...my boost gage hose disc. once causing it not to boost over 15psi...could be a loose hose which you would find by doin a boost leak test if its not visable right away. i'd check there before looking at plugs... |
Your boost level has no effect on how hard it is to hit a certain rpm. Are you sure your car is actually struggling to get to 4k rpm? That would make no sense. 11psi isn't much for the Evo, but it's a lot more than most turbo'd cars, so it should still get to and beyond 4k rpm with ease.
11psi is base wastegate pressure, so you either messed up a recent install, a boost hose fell off, or you're not giving us all the details. |
(Post 5271891)
thanks for the reply's, also id love to give you more details but theres not much to say about something i dont know about, you know? im just trying to figure out the problem with what i know, i understand that makes it harder to diagnose but i do appreciate it. yes i do have a boost gauge so ill check that tomorrow, i did notice something that sounded like it was hissing, but i have no clue where it was coming from, possibly where you both said. so ill find out tomorrow and let you guys know if it was the problem. thanks again.
that happens to me when i put my car all back to stock becuase of my tune.
just put my car back to stock 100% and all I can hit is about 11psi. What can I do?
Originally Posted by evox7
(Post 5413770)
really? I have only one restricor pill off the J pipe that cobb made for me that are back to the stock setting. Where can I get factory boost lines? without having to go to the dealer
no need factory boost lines. something close would still work, as long as the hoses are good quality meaning they wont collapse or be sucked in do to vacumm. the probable issue is improper installation of hoses to the boost solenoid. Read the manual of the car and you'll see that if I'm not mistaken you'll practically connect a vacumm line from the wategate actuator to the turbo nipple, then T off that line to one of the boost solenoid nipple(not sure witch one it is ,look it up) and the nipple thats left of the solenoid needs to be connected with a vacumm line to the intake pipe.
They are hooked up right. I need the second restrictor pill. Thats what is causing my problem
Originally Posted by bevolucion
(Post 5414315)
really? I have only one restricor pill off the J pipe that cobb made for me that are back to the stock setting. Where can I get factory boost lines? without having to go to the dealer |
Do you have a part number, so I can get these ordered from mitsubishi?
It's been posted many times - do a quick search for "boost hoses" or something like that.
same hoses for 8 and 9s?
