In Need of Harness or Connector
As I was going to clean my connectors, i noticed that it was too lazy and they were already completely corroded. Sparks were coming from the engine side connector. Looking for another harness or connector that has been cut but is still good. Its the section that controls the lights, brake line fluid, ignition, basically the entire front end of the car. Need some help ASAP.
You need to hard solder all of those pins eliminating the conectors as stated in the threads postd in the sticky
Here you go,don't say I never gave you anything...
https://www.evolutionm.net/forums/sh...hlight=harness |
Now that I read it and had some tell me what that meant face to face I under stand. The only problem would be is pulling them because of the gap there would be. Is there that big of a gap?
What gap are you talking about. You need to carefully cut the wires one by one and hard solder them together eliminating the connectors all together
