GSC S2's with stock turbo and ecu
The rest of my mods are in my sig.
With this setup I have run a 12.58 @ 111. http://thumbs.vidiac.com/9a9ef9ac-01...6100d9e476.jpgClick here to see Video |
shouldn't this setup run low 12 sec or high 11 sec? b/c my friend's 03 evo ran mid 12 w/out cams.
Brad: How did the swap to the S2's affect your stock turbo's spoolup characteristics in comparison to your previous camshaft setup? Even a seat of the pants assessment would provide helpful insight, thanks!
EDIT: I read on LancerRegister that the S1's spool better than the S2's. What's your take? |
bump for more information.
do the s2's require spring and retainer upgrades? also do you have a vid of the car in motion? cruisin and WOT?; sounds great at an idle. |
Originally Posted by sparky
(Post 5418980)
The dll graph shows basically identical hp and trq curves just that they go higher and stay higher to redline. There is a very noticeable torque punch with these cams. |
Are these on par with HKS 280's specwise?
Thanks Brad! So there is a noticeable gain in midrange torque? I am considering going over to these cams from my present setup. I really want to maximize torque and spoolup. I never rev over 7200 RPM. So, I had been considering the S1's.
Originally Posted by 0E3vobutt3r
(Post 5419017)
do the s2's require spring and retainer upgrades? also do you have a vid of the car in motion? cruisin and WOT?; sounds great at an idle. There are several videos of my car racing here http://dsmvideo.vidiac.com. |
Originally Posted by scheides
(Post 5419062)
Originally Posted by fugiwara
(Post 5418973)
It was my first time at the track. I was only getting 1.83 60's and my stock clutch is finally giving up on me so I had to slow shift into 4th or it would grind its a$$ off. The new clutch will be in by the end of the month so I hope to be able to improve on that time. |
I don't think the stock 16g with the small hotside is helping matters, get that HTA 35R bro :lol:
Hopefully by the end of the summer.
I can't wait, your car is going to be crazy fast.
Originally Posted by Brad@MellonTuning
(Post 5419058)
(Post 5419058)
TIA{thumbup} |
Originally Posted by Aby@MIL.SPEC
(Post 5419982)
can you post your dll compare?
is the punch harder or softer? can you elaborate please. TIA{thumbup} I will have to wait until I get home to get that pic off my laptop. |
| All times are GMT -7. The time now is 05:01 AM. |
