-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Spun a rod bearing...what's the worst that could of happen ? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/340192-spun-rod-bearing-whats-worst-could-happen.html)
omniprobe Apr 19, 2008 12:29 PM
Just wondering what I should be expecting to replace other than the obivious.
scorke Apr 19, 2008 01:29 PM
What do you consider the obvious?
Crank and or Rods could be toast too...
Scorke
JMB8606 Apr 19, 2008 01:35 PM
other than having your motor completely rebuilt. I replaced my oil cooler, oil pump, and clutch when I spun my bearing. Clutch is not required obviously but i would recommend the other two items.
2k4EvoVIII Apr 19, 2008 01:54 PM
Got a engine for sale for cheap! But ya they are right most likely the crank and/or rods are going to be messed up. You should at least flush the entire oil system out when and if you rebuild.
Chris
Wicked E Apr 19, 2008 02:03 PM
You asked for the WORST that could happen...
A rod says hello to the outside world via a hole in the block...
Cheers-
E
scorke Apr 19, 2008 02:38 PM
Agreed, I did too, not knowing the extent of his case might not warrant it but to be honest when spending 2-3k dollars on a new motor why not spend another 500 to have the piece of mind that there is going to be NO metal in the oil.
Scorke
BlownIncome Apr 20, 2008 11:47 PM
Chris
Really, how cheap is cheap? I spun my number two rod bearing about a week ago and now I'm in the market for another motor maybe.
