WOW!!!!! What a Comparison!!!
1 Attachment(s)
So for hose who are wondering what the differences are between 272's and 280's here you go:
1st I have an Evo 8 MR with Brian Crower 272 cams. Just for those out there that want great midrange and pretty good top end. Get them for the money. They are awesome cams and are perform amazing. :thumbup: :thumbup: I will include some DLL (Data Log Lab) power graphs for you. 2nd I now have a 9 turbo and did a run on pump gas w/ the Brian Crower 272's. Now on the 9 turbo I gained 14awhp w/272 Brian Crowers cams over the 8 turbo w/272 Brian Crowers cams on pump gas.{thumbup} {thumbup} 3rd I went with the Comp 280 cams. Ok now this is where it gets awesome. Don't you ever think to yourself that it would be awesome to drive around all the time on race gas. Well here you go I had an Evo 8 MR turbo with Brian Crower 272 cams on Race gas. Then I got the Evo 9 turbo and the Comp 280 cams without race gas and D@MN!!! See for yourself: Here is my other thread to see the other graphs. https://www.evolutionm.net/forums/sh...d.php?t=342959 |
ttt bump
Did you do the valvetrain upgrade as well?
No still on the stock clutch, 45000 miles on it and its time to put in the twin plate.
He said valvetrain, not drivetrain. :lol:
Originally Posted by MR_EVO21
(Post 5685136)
So for hose who are wondering what the differences are between 272's and 280's here you go. . .
The difference in this case is between BC 272s and CC 280s with your particular setup, not between '272s' and '280s' as if they were all the same. Some manufacturers' 272s are effectively larger and better performers than others 280s. And as for the BC 272s and CC 280s, they are timed very differently as well, which is another factor. This is why cam's cannot be compared on the basis of advertised duration (e.g. 272 and 280), unless they are from the same manufacturer. FYI |
Originally Posted by Ted B
(Post 5703143)
Yes and no.
Originally Posted by eponti
(Post 5685343)
(Post 5703143)
Yes and no.
The difference in this case is between BC 272s and CC 280s with your particular setup, not between '272s' and '280s' as if they were all the same. Some manufacturers' 272s are effectively larger and better performers than others 280s. And as for the BC 272s and CC 280s, they are timed very differently as well, which is another factor. This is why cam's cannot be compared on the basis of advertised duration (e.g. 272 and 280), unless they are from the same manufacturer. FYI Thanks for the info I was just showing people my experience with the two different cams. |
this on stock cam gears?
Are you going to make it to fallon this saturday?Might go down there to test Simons tune if weather permits.
Originally Posted by bnice01
(Post 5707596)
No I will not be down there b/c I have to put my new clutch in soon. My clutch is finally going out after 45000 miles on it and a lot of racing.
Sweet...my buddy with his 8 will be excited to see this.
Yes these cams are amazing. They sound awesome at idle real lopey.
