compression test on a used evo
so my buddy bought a used evo 9 and there is a little blue smoke coming out of the tail pipe at wot. so i am going to help him figure out this dilemma.
so some of the things i need to know are.... 1. what the stock compression should be in PSI on a stock evo 2. what fuse to take out to disable the fuel pump so when doing the compression test we dont fill the cylinders with fuel also after i do this i will be checking to see i the turbo is spitting oil. will be checking the intercooler and pipes. so if anyone can chime in and answer some of these quesions, that would be fantastic! also make any sugestions. i will be doing a boost check as well just to make sure he has no leaks. thanks! |
Originally Posted by deadbeatrec
(Post 5720628)
so some of the things i need to know are.... 1. what the stock compression should be in PSI on a stock evo 2. what fuse to take out to disable the fuel pump so when doing the compression test we dont fill the cylinders with fuel also after i do this i will be checking to see i the turbo is spitting oil. will be checking the intercooler and pipes. so if anyone can chime in and answer some of these quesions, that would be fantastic! also make any sugestions. i will be doing a boost check as well just to make sure he has no leaks. thanks! 2. No need. Just disconnect the cam angle sensor. Look for the triangle connector near the right side (if you're facing the firewall) of the valve cover area. Remember, do it with the engine warm and with the throttle wide open. Crank it until about 5 Mississippi and you're good. |
Originally Posted by Exciting News
(Post 5720712)
1. For a IX it's about 145
2. No need. Just disconnect the cam angle sensor. Look for the triangle connector near the right side (if you're facing the firewall) of the valve cover area. Remember, do it with the engine warm and with the throttle wide open. Crank it until about 5 Mississippi and you're good. ok i will do, thanks. any other sugestions to look for? |
(Post 5721827)
so just disconect the sensor and we will be good? that stops fuel from spitting?
ok i will do, thanks. any other sugestions to look for? Good luck. |
(Post 5721919)
That is correct. Your injectors won't fire with the CAS disconnected. It's pretty easy to do. Make sure the tester is threaded snugly but don't ham-fist it. Those aluminum spark plug threads ain't the strongest things on the planet.
Good luck. |
Is this car modded?
You could probably just pull an ecu fuse. If there is no primary ignition, there will be no fuel injector pulse. This way you can avoid a check engine light after your done.
Originally Posted by packrat
(Post 5721984)
and what ecu fuse? u have to be a little more specific here as i have never done this to an evo, only older cars and a svt focus.y would it pull a check engine light? |
It might because your trying to turn the car over with the cam sensor disconnected. Just reset it when your done no biggie
Originally Posted by gsrboi80
(Post 5722099)
but i have a built 9:1 motor in my evo, i wonder what my compression will be. like 175+ i bet. im courious now and i might just do mine. |
