-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   revolver 280's stock valvetrain? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/355210-revolver-280s-stock-valvetrain.html)
bmojito Jul 2, 2008 04:51 PM
i've seen a few people on the board saying they've ran hks 280's on a stock valvetrain shifting at the stock redline and nothing bad happening. i have the opertunity to get a set of revolver 280's from a friend minus the springs and retainers is it ok to put them on the car with out the springs and retians as long as i shift at stock redline? any answers are greatly appreciated. :)
bmojito Jul 2, 2008 06:54 PM
bump.....
andy hiralall Jul 2, 2008 07:27 PM
i think you should get some supertech , since you have the cams out ....
SOEuro Jul 2, 2008 07:34 PM
are you sure they are revolver 280s???? i dont think revolver ever made 280s
i have the 262-264 revolvers....
PVD04 Jul 2, 2008 08:53 PM
No way at all. HKS 280s have 10.8mm lift on the intake side and 10.2mm lift on the exhaust side. The revolvers have 11.4 or 11.5 on both the intake and exhaust sides. I wouldn't even let the car idle with Revolvers on stock springs and retainers.
bmojito Jul 2, 2008 09:45 PM
you are right sir. thanks for pointing out my mistake. they are 262-264 cams. are they safe to install without the springs and retainers?
bmojito Jul 3, 2008 09:21 AM
anyone?
bmojito Jul 4, 2008 11:16 AM
bump
silver evo8 Jul 4, 2008 11:40 AM
dont even try to run these cams with the stock springs you will have a blown motor before you know it.
Revolver 262/264
Advertised Duration - 262 deg Int / 264 deg Exh
Effective Duration - 222 deg @ 1mm Int / 223 deg @ 1mm Exh
Lift - 11.4mm Int / 11.5mm Exh
Lobe Centerlines - 109 deg Int / 111 deg Exh
LSA - 110 deg
Upgraded valve springs required
bmojito Jul 4, 2008 11:45 AM
Revolver 262/264
LSA - 110 deg
thanks for the info so what springs should i look at? and how much should i expect to pay to get them installed?
Draven83 Jul 4, 2008 01:26 PM
well if you dont want the revolver you can run hks 272's on stock springs, BR makes some you can run on stock springs, GSC s1's can have stock springs. You can look it up and see which ones require new springs. Also take into fact about how much you want to build up your car. Install is a few hours. I think like 2 or 3 i have been told.
thebluesky Jul 5, 2008 06:58 PM
Revolver sells their springs with the cams as a complete package. Realistically, you should be looking at theirs as they are made specifically for their cams. Noramlly, the whole package goes for $770 shipped. I'd contact them for purchasing info for the springs and retainers.
skold Jul 11, 2008 03:29 AM
its is not the durations ie that make the 280s not able to run on stock valve train its the lift. hks cams for evos suck. there isnt enough lift. and yest with revolver 280s YOU HAVE TO run uprgraded springs
nothere Jul 11, 2008 05:46 AM
iirc you don't want to run the revolver springs and retainers. there was an issue with the springs.
you do need upgraded springs and retainers.
Exciting News Jul 11, 2008 07:34 AM
Revolver isn't even in business and hasn't been for some time. Not to mention the QC issues with those springs anyway. Even the cams have QC issues.
OP, the inexpensive option would be the supertech dual kit.
