-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Help, I can't split transfercase from tranny evo9 (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/359901-help-i-cant-split-transfercase-tranny-evo9.html)
piotr4net Jul 26, 2008 09:47 AM
Hi All, I have big problem . I wanted to change clutch. I stopped on
split transfer from tranny, on the pict. I cant move it any more.
What to do? What could happen ?
Nothing stop transfercase, allaroud removed (shafts)
Picture:
http://images31.fotosik.pl/332/3a23f8216ee21803.jpg
jmelocik Jul 26, 2008 09:50 AM
I'm at work and can't see the picture but did you remove the stub shaft?
Josh
:usflag:
piotr4net Jul 26, 2008 09:54 AM
Josh
:usflag:
What You mean "stub shaft"? shaft to wheel removed and shaft to read diff removed
1320 Engineering Jul 26, 2008 09:56 AM
is it hitting on the cross member?
pull harder!
Silver05Bullet Jul 26, 2008 10:03 AM
there is a input shaft that goes thru the tranny and conencts to the actual tcase, the other end of it connects to the axel you have to pull that one out
piotr4net Jul 26, 2008 10:18 AM
pull harder!
What You mean cross member? I was afraind to hit anything. Only
insert wood between tc and tranny and try move to trany and back (like on the picture)
Is there any lock on shaft or sth like that?
ps. crossmemebr removed ;)
sabastian458 Jul 26, 2008 10:24 AM
lift up under the transfer case. you are being hung up on the 2nd set of splines going into it. You might have to rotate the bottom of the case back and forth. Once it is loose, it will drop down.
sabastian458 Jul 26, 2008 10:25 AM
have you by chance already removed the transmission bolts holding it to the engine? Some of the movement need to remove the case is gotten by moving the transmission.
ak47po Jul 26, 2008 10:32 AM
http://i87.photobucket.com/albums/k1...g?t=1217093523
feautoevo Jul 26, 2008 10:41 AM
If you haven't removed the "input shaft" which looks like a mini half shaft that is completely internal the tc won't budge send me a pm with your phone number and mabey I can clarify
sabastian458 Jul 26, 2008 10:48 AM
If you can not see thru the hole in the transmission and transfer case where the axles attach, then the shaft is not removed.
feautoevo Jul 26, 2008 11:01 AM
515-571-1288 If you still need help My name is Brett
piotr4net Jul 26, 2008 11:09 AM
Brett , thanks a lot, but I come from Eastern Europe, and my English is very bad, I afraid I will not understand You :(
piotr4net Jul 26, 2008 11:46 AM
should I remove red shaft?
http://images26.fotosik.pl/255/c4a7ee0e8df1794dmed.jpg
sabastian458 Jul 26, 2008 11:49 AM
you actually have to pull it out, but yes that is the shaft. I maybe mistaken on my earlier post, you might not be able to see completely thru the transmission, but you should be able to see the diff inside it.
