Car won't start, randomly.
This is so weird. My car won't start at random times. It would be perfectly reliable for 3 weeks, then one day, it won't start. It's only happens after i've driven the car and stopped for a short while (restroom or to get some food). It never happens in the morning when i first start the car. Battery was checked as fine, and there isn't any water damage from the common leaking area. It acts exactly like my clutch pedal isn't pressed and i try to start the car. everything electrical works, but the car just won't turn over. It won't even try to crank.
Btw, It will EVENTUALLY start after i try to start it several times. But it takes several tries. I have two gauges (boost, a/f). The a/f doesn't work, but lights up. I also have a turbo timer (apexi). What's weird about this TT is that it goes into a small black box, which connects it to the ignition wires, and several other wires that im not sure of. Anyways, i don't think it has anything to do with it because the problem happens even if i turn it off. any help guys would be appreciated. thanks. -dan |
Who installed the turbo timer?
Check your tt wires inside your steering column.
something exactly the same happened with another evom member - Shocky.
He had some issue with some clutch switch something.. will ask him to reply here.. |
Originally Posted by EvoHung
(Post 6014670)
Or it could be some other sensor on it's way out.
Originally Posted by evo_q8
(Post 6014683)
im not sure if it's my clutch pedal switch because i've disconnected it before, and it won't start.
THis means, that i can start the car without pressing the clutch. But with this issue, i still can't start it no matter if the clutch switch is connected or not. |
The TT seems to be connected using a harness.
could be a loose connection.. check your battery cables also..
| All times are GMT -7. The time now is 07:52 AM. |
