can't boost over 28psi help help
i have a t67 25g turbo kit on my car and it just wont boost over 28psi does anyone know why and i am using buschurracing mbc it just wont go over that.
We would need far more details than what you've given us.
stock ecu? BOV setup?
boost leak? ^^just pm warrtalon and get it over with. :) |
i mods are hks 272/272, rebuilt head, 255 fuel pump, aem ems, meth injection, super tech value spring and retainer, mbc and a 3'tbe, 1000cc injector.
Test pipe or high flow cat?
Originally Posted by wkehn
(Post 6036871)
What BOV/DV?
Originally Posted by markymark1082
(Post 6036921)
What BOV/DV?
sounds like you need a bigger boost selenoid
You will most likely need to swap out the spring in your wastegate for a higher pressure one. Do you know which color is currently in your setup?
Originally Posted by rgeier11
(Post 6036974)
I had to upgrade to dual springs in my Tial 44mm to get past 28psi;)
Originally Posted by EVO8_PR
(Post 6037507)
Well its sounds like it's possible your BOV or your MBC.
| All times are GMT -7. The time now is 04:18 PM. |
