Q's about Evo 9 and 8 Stock Turbo
Sup guys, Buddy of mine and i are trying to do a project on our SRT-4's by running some Evo turbos on our stage 3 manifolds. Its been done with an Evo 8 turbo but were gonna be trying something new by trying to run the Evo 9 turbo.
My Q's are: Does the 8 and the 9 both share the same turbine wheel size as far as the inducer and exducer? Im aware of the bigger exhaust housing 9.8 vs 10.5 thats not what i want to know. Also is the exhaust flange on the CHRA(Piece that hooks up to the exhaust housing then with the turbo clamp) the same size as the Evo 8? Im also aware that the Evo 9 compressor housing is much bigger hence the reason why we want to run it. Thanks! |
03s and 04s have the 9.8 with the small comp housing.
05s have the 10.5 also with small comp housing 06s still have the same CHRAs as all prior usdm models with the 10.5 and larger comp housing. all flanges and threads are housing the same just a different coolant line bolted to the comp housing and a different outlet on the housing has a lil different angle aswell so it doesnt go into the starter if put on a earlier model. I think this is more then you needed but wanted to be clear with everything |
Originally Posted by whitey4d
(Post 6111106)
05s have the 10.5 also with small comp housing 06s still have the same CHRAs as all prior usdm models with the 10.5 and larger comp housing. all flanges and threads are housing the same just a different coolant line bolted to the comp housing and a different outlet on the housing has a lil different angle aswell so it doesnt go into the starter if put on a earlier model. I think this is more then you needed but wanted to be clear with everything Ok but to get the most important thing straight, The CHRA exhaust side flange are exactly the same? For example you can take the 9.8 housing of an Evo 8 and mount it to a Evo 9 turbo? Im sure know one want to do it but itll give me the answer im looking for. Thanks for the great Info!{thumbup} |
Yes you can take the 9.8 and 10.5 hotsides and interchange them. This is very common on the 03-04 turbos, to put the 10.5 hotside on them. As far as saying no one would put the smaller hotside on, actually if you put a ported 9.8 hotside on say a green it will spool stupid fast but will lose some on the top end. If you are putting these on say an SRT4 2.4 which doesn't rev as high it would not be as much of a loss at say a 6800 rpm redline and the faster spool would more than make up for the slight loss at that rpm. Also there are a few rare 9.0 hotsides around somewhere. Good luck finding one though! They would spool even faster!
Josh :usflag: |
I am ot sure that this is an answer to your question, but here it goes: There are three different turbine housing sizes for the MHI 16G turbos. These are the 9.8, the 10.5, and the 9.0 housings. These housings are interchangeable between both the IX and the VIII turbos.
You can take a 9.8 housing from an 16G VIII turbo and swap it directly onto a IX turbo. Vice versa, you can take a 10.5 turbine housing from a 16G IX turbo and swap it onto an VIII turbo. There are some subvariant 10.5's. The first 10.5's had a dual flapper WG puck, while the later ones were configured with a single puck WG. I think that all of the 9.8 & 9.0 housings were dual puck. But, correct me if I am wrong. At any rate, as long as we are going with a stock turbine wheel, all of the stock housing sizes are interchangeable between IX & VIII 16G turbos. |
Originally Posted by sparky
(Post 6111149)
You can take a 9.8 housing from an 16G VIII turbo and swap it directly onto a IX turbo and vice versa, you can take a 10.5 turbine housing from a 16G IX turbo and swa it onto an VIII turbo. There are some subvariant 10.5's. The first 10.5's had a dual flapper WG puck, while the later ones were configured with a single puck WG. I think that all of the 9.8 & 9.0 housings were dual puck. But, correct me if I am wrong. Alright perfect, Thats exactly what i wanted to hear. I dont care to much about the housings aslong as the CHRA exhaust flange is the same size as an 8 it'll bolt up straight to our stage 3 manifolds. Thanks guys!{thumbup} |
Originally Posted by SlowSRT03
(Post 6111125)
.... but to get the most important thing straight, The CHRA exhaust side flange are exactly the same?....
The turbine housing/CHRA fitment is via a circumferential machined groove and lip. At any rate any of the three basic housing sizes will mateup perfectly with the CHRA on the hotside. EDIT: And all three above mentioned exhaust housings have the same identical turbine inlet flange footprint which mates to the cast factory exhaust manifold outlet flange. All use the same gasket at this juncture as well. |
Ill make this simple... Yes, They all have the same flanges
stupid question....could you unbolt your VIII turbo and bolt on a IX turbo and be good...i know you'd have to retune but thiers no fabrication is there?
Originally Posted by nightfighter29
(Post 6111233)
(Post 6111233)
Josh :usflag: |
Originally Posted by kreionic
(Post 6111247)
yes
Josh :usflag: |
(Post 6111170)
What exactly do you mean by, "CHRA exhaust side flange"?
(Post 6111149)
You can take a 9.8 housing from an 16G VIII turbo and swap it directly onto a IX turbo. Vice versa, you can take a 10.5 turbine housing from a 16G IX turbo and swap it onto an VIII turbo. There are some subvariant 10.5's. The first 10.5's had a dual flapper WG puck, while the later ones were configured with a single puck WG. I think that all of the 9.8 & 9.0 housings were dual puck. But, correct me if I am wrong. At any rate, as long as we are going with a stock turbine wheel, all of the stock housing sizes are interchangeable between IX & VIII 16G turbos. http://homepage2.nifty.com/lancer/wg1.jpg On my housing the flapps are hold not centrally but by an axis at two points. I searched a lot and found nothing. I would also like to ask, if there is a difference at the turbo boost behaviour of a stock IX with single or twin puck housing, I mean was it maybe a mistake to install this housing or should I search for a stock single flapper? |
(Post 6111106)
| All times are GMT -7. The time now is 06:13 AM. |
