-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   cam position sensor - if you've done cams, please come in (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/37250-cam-position-sensor-if-youve-done-cams-please-come.html)
AvatarOfWar Aug 30, 2003 06:17 PM
When I took the CPS off, I did not get a chance to see which way it was positioned. Inside of the CPS, there is a round ring which spins freely - it has gaps between each side of it. One side is smaller than the other - does anyone know if the big end or the small end goes on top?
gunzo Aug 31, 2003 05:25 AM
Re: cam position sensor - if you've done cams, please come in
the small vane ( smaller metal piece ) is at the 10 o clock position
AvatarOfWar Aug 31, 2003 06:39 AM
yep, we figured it out - there's really only one way it goes where it makes sense.
thanks though,
Cris
