-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Drop In's (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/383737-drop-ins.html)
MrJdmJimi Nov 25, 2008 09:17 AM
Drop In's
Well it getting to the point where i dont think stock rods and pistons can handle much more .. I Want to build the engine but i hear drop in's would be fine .. The car has about 25,000 miles on it .. Car Will be on Aem Ems
Who on here has drop in's ? What kind of numbers do you make ? Any Problems ?{thumbup}
SOEuro Nov 25, 2008 09:23 AM
ive heard they are not good on higher milage motors because the block may need to be machined
my friend just did his on 47k miles(and rehoned the walls) and its running fine
6-speed Nov 25, 2008 06:20 PM
There was a very informative thread a few months back about this subject.
https://www.evolutionm.net/forums/sh...highlight=drop
I learned a lot from reading the thread since some big shops (David Buschur from BR, Scott from TTP, and JAM) gave valuable information therein.
I've been thinking about this option for my car, but I have much fewer miles than you (approx. 11,500).
BTW, to my knowledge, BR and TTP do drop-in setups.
wevo1985 Nov 25, 2008 06:24 PM
i would req still having the machine shop clean and hone the block. also would req replacing all the bearings and putting apr studs in. if you have a good block and machine shop, i would do it.
whitey4d Nov 25, 2008 06:31 PM
I think Im gonna have BR do mine pretty soon. IF there in their and something doesnt look good Ill bite the bullet and go stg3. If no other problem on a strong running engine and low mi Id say go for it.
Joshs EVO Nov 25, 2008 09:32 PM
BR has a machine that hones the block in the car I think from what I remember about that thread.
I am sure he will chime in.
SpeeDeviL Nov 25, 2008 10:04 PM
I might do drop in the future, and I know 2 of my friends did drop in's, one of them as some series power, and plans on getting the FP Red, imagine the power gain from that setup.
The only down side to drop in is the balance shaft, unless you get a balance shaft eliminator kit!!
RSGuy Nov 25, 2008 10:12 PM
You can hone and deglaze the cylinders without pulling the motor. As long as they dont need to be bored, you can do it without pulling the motor.
MrJdmJimi Nov 25, 2008 11:30 PM
Well plans were to eliminate balance shafts ..
