-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   2.3L and their max RPM's (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/388505-2-3l-their-max-rpms.html)
less10 Dec 19, 2008 07:15 AM
I am in the middle of building a motor for my setup. Im going to run a TS 35r since I ditched the 40r idea. I just came from the honda world. I keep reading about not revving the 2.3 stroker motors out past 7500-8000. Well here is my thinking and why I believe thats a very low rev for such a potent motor.
I was running a k24 bottom end out of a crv stock. It has a 99mm stroke with a 152mm rod and 9.114" deck height. I would rev it to 8200 on a stock bottom end with just a k20a2 oil pump and a built head. The 4g63 deck height is 9.010 and with a 100mm stroke and 150mm rods its very similar to the honda k24 engine. Now with a built bottom end as well as head, why is there no reason we cant take these motors to 8500?
Ive also been toying around some other crank options like the 94mm crank in a 4g63 block which will yield 2.1L which might be the best bet. I like the idea of the added tq. but hate the possibility of taking my car to the track and running out of rpm's in 4th and having to shift to 5th. Doesnt make for a good et.
Let me know what you guys think. Am I being overly paranoid about the motor and its revving situation?
TIA
EvoFlash Dec 19, 2008 07:20 AM
I know ppl with 2.3 going to 8.5 all the time when racing.
evilbada Dec 19, 2008 10:43 AM
you can rev these to 9k if you want. But it will shorten the life of the motor dramatically.
Piston speed of the stroker at 8.5k is very high compared to 2.0L. refer to 2.0 vs 2.3 sticky
Just destroke a 2.4L block to 2.1L or just have your 2.0L built if you want the rev. Latter will be a much cheaper option.
Instead of torturing yourself, you could simply call up reputable shops here on evom and ask for their professional opinions.
haseeb Dec 20, 2008 12:16 AM
8000 for daily driving and 8500 for races ...
DIDYSIS Mar 11, 2009 01:35 AM
I think I am going to stick with 7500 :-)
1BAMF Mar 11, 2009 06:05 AM
8400 on my AMS 2.3 w/oliver rods and CNC head. But if you can afford it and like the best of both worlds 2.3rr has your name all over it. Keep us posted :)
Bggstin Mar 11, 2009 06:17 AM
I rev the 2.5 past 8k. It's not a 2.4L block either, it's a 2.0 -> 2.5. So I wouldn't see why a 2.3 couldn't do it all day long.
This is using a stock head, also no balance shafts.
sabastian458 Mar 11, 2009 06:19 AM
daily driving i would not push higher than 7500-7600. Now if you just use if for racing then they are capable of 8500-8800
obviously that is dependent of the valve train and wither you have balance shafts or not.
zbomb Mar 11, 2009 06:24 AM
Originally Posted by davidbuschur (Post 6781602)
BTW, yes, 8500 rpm is safe with our stroker kit.
Thread is here
1BAMF Mar 11, 2009 06:31 AM
Originally Posted by zbomb (Post 6795242)
Thread is here
Im sure its safe on many 2.3's but longgevity is another topic.
Sharkbite2000 Mar 11, 2009 06:36 AM
8500 for me :) 44+ psi a year so far didn't even have to change my bearings ;)
andrewzaragoza Mar 11, 2009 06:37 AM
it all depends on what combination you use with your engine internals. ie. piston, crank, rods. the best thing to do is talk to your engine builder and talk options.
zbomb Mar 11, 2009 07:31 AM
Dude...Read the quote. It says what it says. 8500 RPM is safe. I'm not going to parse what Dave means by "safe".
1BAMF Mar 11, 2009 11:07 AM
Dude(:lol:)...Im not really going to get into this p*ssing match. But Im sure there are lots of factors in this wide opinon, like fuel used, boost, how offten is it going to be pushed to 8500rpms and such. Your going off a direct statement he used at that time. And ask anyone out there about the difference of can it take it and longgevity. Im sure Buschurs 2.3 can handel it no dought, but if the OP chooses to take it to 8500 every shift every day dont you think it would decrase the life span of the motor....:rolleyes:
1BAMF Mar 11, 2009 11:09 AM
Money {thumbup}{thumbup}
