CEL light trouble........
I got two codes today. P1400-manufacturer control auxiliary emission controls, and P0121- TPS/Pedal Position Sensor A CKT Range/Perf. Does anyone here think the problem is just a faulty TPS sensor, or is it something else?
i would try to have the sensor adjusted first. what intake are you running and turbo. i had the same codes when i was running the fpgreen with too short of a intake tube. i think there is a tread on here about it.
If the TPS was going bad or is bad, I would think the car would run like poo.
Originally Posted by wevo1985
(Post 6509657)
Originally Posted by MR_Evo_Rob
(Post 6509697)
try to recalibrate the sensor first. much cheaper and might fix the problem
(Post 6509725)
You should try and post this in the tech section... You might get better feedback. I would say, change the sensor, it prob went bad...
