It's a foking DSM afterall!
So the common thread with all things evo related is that they are reliable, powerful, and streetable. That's how I always have felt, it's an evolution of what dsm's were. Where they failed, the newer evos strive, blah blah blah. No I didn't mean to preach it or really really heartfully mean it because the newest dsm is 4 years older than the oldest evo (USDM).
I lost a little faith in my evo recently, and really it's just the icing on the cake of **** that's happened with it recently. I am *never* nice to the car. It gets driven 40-100 miles per day, several hundred miles per week, and over a thousand miles per month. I'm playing with E85, alky, pushing the tune, blah blah blah so really some of this stuff comes as no surprise. Water pump leaking, check. Timing belt tensioner on backwards, check (all me). Headgasket, check. Water pump freeze plug blowing out on xmas day, in front of 2 members and later 20+ members of my family, check. Weird-ass electrical gremlins popping up out of nowhere, check-check-WHAT? That's right, go mitsubishi. There's a seal that goes through the fender that leaks. No recall, nor a TSB (that I've found). Yet water leaks in, dripps down onto the main wiring harness and its 6 big plugs, and then goes ahead and corrodes the living **** out of them. I'll let the pictures do the talking, I can't believe I had to do this to my *2005* evo. It's still ****ing new to me. Soldering to follow. http://www.scheides.com/albums/Dec20...9402.sized.jpg http://www.scheides.com/albums/Dec20...9403.sized.jpg Screwdriver points to the faulty seal thingy: http://www.scheides.com/albums/Dec20...9408.sized.jpg http://www.scheides.com/albums/Dec20...9409.sized.jpg http://www.scheides.com/albums/Dec20...9410.sized.jpg http://www.scheides.com/albums/Dec20...9411.sized.jpg It's winter in MN, water gets everywhere! EVERYWHERE! http://www.scheides.com/albums/Dec20...9412.sized.jpg |
ps--my car has 63000 miles on it. Not that mitsu would do anything about this anyways.
hey wasnt there a member here that had all his wires replaced under warranty for the same thing?
Sorry to hear about your troubles scheides. All that really sucks, but i guess that what happens when you live where it snows. We have it pretty good in California, except for the smog regulations and crappy gas. Good luck with your evo.
Hmmmm....this is actually kind of scary. I really hope this is a rare occurance. Anyway, im sorry to hear about your situation.
Originally Posted by DRAGHICI
(Post 6518308)
I thought this was in a tsb, seen a few posts about it... sorry to see that though... lots of unnecessary work
Originally Posted by Lilredbox
(Post 6518366)
Little bit of sealant around that grommet is a good preventative fix. Hoping I make it all winter, gonna check in the spring :) |
Pretty frustrating but seems to be somewhat common given the size of the other thread. Did you seal around the grommet after you rewired everything?
Where is that connector exactly? I'm going to go ahead and fix that problem. Pics, please, if its possible
The pics are posted here and the other thread people are talking about is here:
https://www.evolutionm.net/forums/ev...zy-help-3.html This is behind the driver's kick panel. Pop it off and you cannot miss the 7 big plugs there. I got the wiring done tonight and sealed up the grommet. It was a ***** to get all the silicone up in there nice and smoove. Not a fun job. Car drives like it should now. Maybe this is the trade-off I get for having E85 around every corner!? |
Originally Posted by scheides
(Post 6519575)
I was going to use RTV, but I ended up getting some 100% silicone sealant at menards for about $3. Application temps -35 to 135 F, good thing I had the heater on in the garage last night; it's -15 this morning :)
ps--I originally posted this in 'evo general' and now it got moved to turbo-engine-drivetrain...wtf mods!?? what does ecu wiring and water leakage have to do with the turbo, the engine, or the drivetrain? I mean arguably they are related, but then again so is the trunk lid and the rear seat belts...
(Post 6520511)
| All times are GMT -7. The time now is 11:39 PM. |
