-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Manley Turbo Tuff's vs. Crower's (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/391705-manley-turbo-tuffs-vs-crowers.html)
norcalSRTrida Jan 7, 2009 12:54 PM
How's it going guys. I'm basically set on either 1 of these two rods for my build. currently have a HTA30r, but will upgrade to a HTA82 or 6262 in the future after the motor build for 550-600hp...
I know its all a matter of opinion when dealing w/ very good rods as such, but which would you prefer?
the turbo tuff's are 3/8" ARP 2000 rod bolts. Are the Crowers 7/16"?
How can Manley state their turbo tuff i-beams are good for 1000hp, yet the ARP-2000 rod bolt's hp threshold is 800hp (200hp/rod rating)?
Call me skeptical, but i'm just a tad weary doing 27-30psi and worrying about rod bolt failure (extremely rare i know, but i just dont want to piss $ down the drain).
i do like the fact that both are shot-peened, magnafluxed, and somewhat balanced before leaving the doors. tolerances of the Crowers are w/in +/- .0001" while the Manley TT's are +/- .0002", so extremely close.
gimme some opinions. thanks guys.{thumbup}
Mike
oh, and i've read every informative thread/posts that pertained to the two rods in regards to success/strengths that popped up in the search, tho pretty lackluster.
dryad001 Jan 7, 2009 01:00 PM
The only advise I can offer is with the Manley rods, when my builder put everything together all the rods were within 1 gram of each other. I would have to give him a call and ask what the tolerances were since I had him keep my build sheet.
norcalSRTrida Jan 7, 2009 01:04 PM
w/in 1g is pretty good.
my machinist is gunna get the whole piston/rod assemblies w/in .5g of eachother.
my last motor i dropped CP's in on stock rods...and lets just say, this is the reason why i am building another motor... so im pretty paranoid, and will make sure everything is spec'd and balanced as best as it can get.
thanks for the insight.{thumbup}
oh, and did you get the manley H or I beams? and what ya putting down?
norcalSRTrida Jan 7, 2009 01:09 PM
**deleted due to it showing up twice
Celica2EVO Jan 7, 2009 01:25 PM
Order a BR stage 3 head and block. 576 hp on PUMP gas on the BR Heartbreaker dyno. Id say the crower rods in my motor are doing great. since this set-up has about 14k miles on it and over 50 passes in the 9s and 10s last year. went 10.38 on pump and 9.89 on Q16.
norcalSRTrida Jan 7, 2009 01:41 PM
props on your numbers and 1/4 times man. definately amazing. {thumbup}
unfortunately, i cant afford to buy a BR kit due to a budget. i have some strings thru a very reputable shop locally that will build it all for me.
My main concern is mainly geared toward the capabilities of the ARP-2000 3/8" rodbolts, and whether or not Crower's have 7/16" rod bolts or not (on some car models they do).
Erik@MIL.SPEC Jan 7, 2009 02:01 PM
You can always upgrade the rods bolts. ARP custom-aged 625's for example.
03whitegsr Jan 7, 2009 02:08 PM
I'm pretty sure the Crowers use ARP 2000 (or eqv) 3/8 bolts as well.
Rod bolts typically fail from RPM and not power though.
Chris@nolimitmotors Jan 7, 2009 02:10 PM
We always use Turbo Tuff's.
norcalSRTrida Jan 7, 2009 02:17 PM
that's a hefty cost to upgrade isnt it? life for example, my bud was quoted for 380 for BC rods w/ ARP2000's, and the same rod w/ the custom aged's for like 630 i believe...:eek:
those bolts really that much better/cost effective?
norcalSRTrida Jan 7, 2009 02:21 PM
RPM, torque, and detonation are the prime factors. detonation isnt an issue (im an extremely conservative tuner...low to mid 11afrs on race gas AND meth), and rpms wouldn't so much either (7500, w/ the occasionaly slightly higher shifts when necessary).
maybe im being just a lil too paranoid about using the standard ('economy' as some call it) rod bolts?
dryad001 Jan 7, 2009 02:22 PM
I think the "tuff" rods are i-beam but I could be wrong, id have to look at the box again. I havent gone to the dyno yet since Im still in the 500 break in period and with winter here I think I have 6-10 miles on the engine. Once its all said and done Ill be happy with 700 and thats all I want, anything over that will be too much for the street. If you search my threads I have my build in there but I probably wont update it since there isnt much interest in it. People would rather read about a shop who built their car for them.......
norcalSRTrida Jan 7, 2009 02:25 PM
they look like an awesome and very sturdy rod. any particular reason why you choose the manleys over crower?
thanks:beer:
norcalSRTrida Jan 7, 2009 02:27 PM
sorry about that, i was unclear. you're correct. the tuff's are i-beam. they do have a lower grade model in h-beam form though.
i will def. check your build thread out. solo builds are FTW. nothing like buying/piecing and assembling a motor yourself and enjoying the piss out of it.{thumbup}
cthcky5 Jan 7, 2009 02:32 PM
interesting thread...subscribed
