Some things I did over winter...
Well after Finishing my Garage at my new house. It was time to Do a little few things to the car ths winter that I didnt get to before.
First was to Install my mustache bar eliminator kit, this makes the rear end solid and saves a good 15+ lbs, Next was some shifting bushings, and a lower clutch line. Then it was time to get ride of some usless brakets and such, and remove my intake manifold to get ready for my new one. https://i114.photobucket.com/albums/...ox/misc001.jpg New JDM EVO 7 Tail lights https://i114.photobucket.com/albums/...ox/misc010.jpg New Mustache bar replacement bracket https://i114.photobucket.com/albums/...ox/misc009.jpg https://i114.photobucket.com/albums/...ox/misc013.jpg Got Bored painted the rear end https://i114.photobucket.com/albums/...ox/misc006.jpg Missing Intake Manifold :biggrin: https://i114.photobucket.com/albums/...ox/misc005.jpg Re-Routing Vacum Lines Took the ABS out of the Car. Cleans it up alot!! also saves me about 10lbs https://i114.photobucket.com/albums/...ox/misc002.jpg did a little work on this bracket. Un painted nasty green... :sleep: https://i114.photobucket.com/albums/...ppBox/misc.jpg Painted, with a few tricks. and all sensors put back on. :supz: https://i114.photobucket.com/albums/...ox/misc003.jpg Got Me a Fluidampr, on and installed https://i114.photobucket.com/albums/...ox/misc004.jpg Got my brake parts: What comes with the kit, Even comes with the OEM Clips! https://i114.photobucket.com/albums/...obrakes001.jpg Master Cylinder on. https://i114.photobucket.com/albums/...obrakes002.jpg All lines installed, filled back up with fluid. https://i114.photobucket.com/albums/...obrakes003.jpg So much more room on this side! https://i114.photobucket.com/albums/...obrakes004.jpg Got some new Wastegate springs, 23psi compared to the 19psi ones I had, now 49psi will not be my limit :rolleyes: https://i114.photobucket.com/albums/...voparts002.jpg Trying some new oil out this year, guess its the best anti-wear out. https://i114.photobucket.com/albums/...voparts001.jpg Here is the Tab-Fab Rear Motor mount that was made, some installed pics! https://i114.photobucket.com/albums/...voparts003.jpg https://i114.photobucket.com/albums/...voparts004.jpg Thanks to AMS, STM, Tab-Fab for all the parts!! Will update when i get my New AMS Intake Manifold{thumbup} |
NICEEEE looking clean in there!!!
Awesome build.
Where are you in Iowa? You should come up to Minneapolis for MitsuStyle.com's spring dyno day (announcement coming shortly)!
Car looks killer! |
NICE. Who makes the mustache bar replacement?
Thats the AMS mustache bar replacement kit
thanks jbergmeier!
Nice!
How about more info on the fabbed motor mount?
The motor mount is a Custom unit. It saves 4lbs off the stock one, is made of S.S. but is 100% solid. I would only recomend it to someone that has a solid front motor mount, like the AMS one. This is a prototype one off as well. A Jig was made, but some modifications need to be made if there is to be more made.
clean clean clean job {thumbup}
how bad was it deleting abs?? SOO much more room i love it!!
nice
Curious why you removed the ABS?
Maybe you can get a parachute instead; your car definetly looks to be fast enough to warrant one :D. |
i bet that AMS intercooler must've cost an arm and a leg. nice pics..
