-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   New O2 sensor, now won't Start HELP!!! (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/418359-new-o2-sensor-now-wont-start-help.html)
minimkiv May 3, 2009 02:48 PM
I installed a new Bosch O2 sensor (15733) using the following· EVO - Bosch· Blue - Black· White - Grey· Black(2) - White (2) Now the car will not start, turns over but no start. Tried to read the codes using an OBDII and kept getting a “Fail” message. Did I some how screw up the ECU? This is my nephews car and I really hope I did mot mess it up. Note:Reattached the old sensor and still will not start
reyrey May 3, 2009 02:53 PM
have you tried re-setting the ecu?
minimkiv May 3, 2009 02:57 PM
How do I do that?
reyrey May 3, 2009 03:15 PM
just un plug the battery. leave disconnected for a couple of seconds. 10-30 maybe.
minimkiv May 3, 2009 03:34 PM
Left it unconnected for 10-15 min's, no change. Additional info: I pulled the spark plug wire from the coil and did not get a spark when I jumped the coil to ground when cranking the engine.
sikrsix May 3, 2009 03:38 PM
Sounds like you fried the ecu. You can unplug the 02 sensor, have a bad one and it will start. It will throw a code, but it will run.
reyrey May 3, 2009 03:41 PM
i'd have to agree. ecu fried my friend.
reyrey May 3, 2009 03:42 PM
you should be able to find one on here tho. gl!
Kracka May 3, 2009 03:55 PM
Did you disconnect the negative battery terminal before doing any work?
joehoo May 3, 2009 04:49 PM
lol ^^^^^ where do you some of you guys come up with this.....
man check some of your fuses. start under the hood and go from there. gl
minimkiv May 3, 2009 05:50 PM
I'm praying it's not the ECU, and no I did not disco the battery but was VERY carefull to be sure no wires crossed. I'll check fuses tomorrow, any idea of which ones to look at?
dan l May 3, 2009 06:00 PM
rtfm
Import Junky May 3, 2009 06:04 PM
not sure myself....hope you get it worked out.
vicksen May 3, 2009 06:19 PM
Definitely check your fuses. I'm not sure how you could fry an ecu by changing the o2 sensor, maybe if you attempted to attach a tazer to the o2 harness. You didn't did you? Didn't think so. Your engine bay fuse box will have a diagram on the inside of the lid, check every fuse that has a picture of an engine corresponding to it's position. After that check the rest for good measure.
dan l May 3, 2009 06:22 PM
Originally Posted by vicksen (Post 7016586)
I'm not sure how you could fry an ecu by changing the o2 sensor, .
The O2 sensor has 12 power, ground, shield, and signal. Do the math......
