are these hks cams?? PICS
hey would anyone know what kind of cams these are and are this valve train stock?.. i was told they were hks 272s when i bought it. so anyway recently took my valve cover off and started looking at them didnt see any hks markings let me know
http://pic20.picturetrail.com/VOL142.../365413414.jpg http://pic20.picturetrail.com/VOL142.../365413403.jpg http://pic20.picturetrail.com/VOL142.../365413390.jpg |
i know for a fact that hks272's say hks somewhere on there.. its big and noticable
yea
it should say it on there
I had a similar issue. I ordered some HKS 272's on this forum. When I got them there were no markings. After speaking with customer support and many other people it has been confirmed that the original HKS cams didnt have HKS stamped on them. Even if there isnt HKS stamped there would be a part number engraved on it. I cant make out what the part number reads on the rough casting in that third pic. Here is what you need to do. Copy down the part number. Call up HKS technical support and have then reference your number with their part number. Hope this helps.
Most HKS cams have HKS engraved in them. I have HKS cams from 2005 and they still have the engraving.
I've heard that some don't have HKS engraved, but most do.
However, no matter what, there SHOULD be a part number or something along those lines somewhere on the cams. Find what you can, Google what you find, and it should come up with what cams they are. |
from the pics, they look like OEM cams...just like any other no stamped cams
Have you looked on the underneath side? If not, use a small mechanics mirror, or just hit the starter a tiny bit - be careful of the gas if you have the plugs out, etc... shouldn't be even a noticeable amount of gas though.
It seems unlikely that the markings would both be underneath at the same time, but I never really noticed on mine if they are in the same place from a rotational standpoint. I have a spare HKS cam that I'll try to remember to take a look at and see where the markings actually are located on those. I think mine are either from 2004 or 05 You can check with a shop that has some on hand as well. |
they dont look hks to me but ill show u how to find out if u have thrue HKS CAMS OR JUST some fake cam in that 4g63 boy ......
22002-AM001 22002-AM002 these r 264 inatake and exhaust 22002-AM003 22002-AM004 these puppys r 272 intake and exhaust 22002-AM007 22002-AM008 and these 280 hks now this r the codes , now these codes r written sometimes by hand on the cam engraved on it , there not very easy to see but those cam on the photo look like hkz to me instead of hks |
heres a link https://www.evolutionm.net/forums/sa...cams-sale.html
so u can see the codes on the cams buddy , hope this helped u man |
i just installed mine this, month and u can see the "hks" and part # like on those pics above... i did a mivec ix intake 272 and and ex 272... so i know that for a fact both should have it... good luck...
yea ima try n rotate them some all i really see now is "DG" markings ill see if i can get rest of numbers as well
they actually have "DGAD" "DG ES-4604" "BC0111-IN" maybe theyre brian crower
