-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Car cranks but won't start, Check Engine light blinking... (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/424408-car-cranks-but-wont-start-check-engine-light-blinking.html)
MTRJunior Jun 1, 2009 07:53 AM
Hey guys,
I'm having a big problem with my car. It all started on Friday, I drove the car to the airport to pick a business partner up, on the way back I was doing a little bit of spirited driving, went through a toll, and stopped for gas. It was one of those gas stations right beside the highway so when you're leaving the gas station you immediately have to merge into a bunch of traffic....well, no one was leaving a lane opened for me or giving space for me to merge, so from the stop sign I 2 stepped and launched the car into the lane and merged into traffic...about 2 seconds into the launch the car started sputtering and turned off on me.
I tried to turn it back on but it would only crank and not start, the check engine light is also being really weird, it's blinking on and off pretty quick. I got the car towed back home and reset the ecu to see if it would help, but the car still won't turn on.
Any ideas of what the problem could be?
Here are my mods:
AMS GT35R
880cc Injectors
AMS Fuel Rail
Walbro 255lph
Kelford 272 Exhaust Cam
Kelford 272 Intake Cam
AMS Full Turbo Back Exhaust
AMS FMIC
Upper IC Piping w/ HKS BOV
AMS Small Battery
Exedy Twin HD Clutch
Evo Throw out Bearing
Profec-B Spec 2 Boost Controller
AEM EMS Standalone
rcheung Jun 1, 2009 08:01 AM
Did you get the code scanned?
kwanza Jun 1, 2009 08:17 AM
that your factory ECU knock warning
kwanza Jun 1, 2009 08:18 AM
nevermind, didn't notice the standalone...
bluebanana23 Jun 1, 2009 08:18 AM
^ that feature is not stock, has to be tuned in there
kanyonkid Jun 1, 2009 08:24 AM
u became a victim of the dirty water gas pump.... This just happened to my buddy.. syphon out some gas in a clear baggy and you will not like what u see
J8dailo Jun 1, 2009 02:35 PM
i worked on couple car had the same problem...crank and no start no matter what...found bad gas in tank....water in tank...i would disconnect the fuel line and crank car couple time to pump some fluid in a bottle...let it set for a while and see if there is any water in the gas
MTRJunior Jun 1, 2009 11:08 PM
...and if there is, I gotta drain the whole thing out huh?...FML
Benja Jun 2, 2009 12:14 AM
Did you check to see whether you broke a timing belt?
Just trying to help rule out the basics and the symptoms you mentioned in the OP are timing belt ones.
Just take the oil cap off, shine a torch in there and get someone to crank the car and see if the sticks are turning.
MTRJunior Jun 2, 2009 02:22 AM
I went to take some gas out of the tank, so I unscrewed the 12mm screw on the bottom, and just my luck the ****in thing falls right into the bottle and I spill gas all over my garage...FML lol
Gas looks fine =\
Slo_crx1 Jun 2, 2009 03:08 AM
Finicky crank sensor perhaps? I had this happen to me once and it turned out to be a bunch of metal shavings caught in the crank sensor that was screwing up the signal. I'd say to pull a plug out and leave it connected to the coil, ground out the base of the plug, and see if you have spark first. The motor needs 3 things to run...air, fuel, and spark. Figure out which one is missing and you should be good (and more than likely it's not air lol).
MTRJunior Jun 9, 2009 12:03 AM
ok...the check engine light stopped blinking. the gas now primes, but I get no spark. I'm also unable to connect to the AEM =\
dtuned Jun 9, 2009 03:40 AM
You forgot timing. If the crank timing is off, it won't start. It's possible your belt slipped and threw the timing off. Before going there, make sure the crank sensor connection is intact. If it is, check the sensor and clean it with contact spray and re-install. If it doesn't start, check to make sure your belt didn't break by checking to see if the cams turn as the post said previously (need a friend to help with this). If the cams are turning, the possibility of the belt slipping is fairly certain, ruling out bad gas or a bad sensor.
OhsixIXBish Jun 9, 2009 03:59 AM
If the timing was off or the belt was broke It would turn over real fast a nd u would be able to tell.
EvoDom Jun 9, 2009 05:41 AM
thats what you get for 2 stepping and launching your car to merge :lol:
my vote would be water in your fuel, bad gas is the culprate.
fill up with 100, 110 octane to clean things out.
