Tomei ECU installed
I just got a used Tomei System 1 ECU installed today, I could immediately feel the difference. The max boost is still 1.3 bar controlled by the EBC, but the engine rev up a lot faster after 3000 rpm, and the turbo sounds louder I don't know why. The low end torque(below 3000 rpm) is noticeably weaker than stock, I guess too much fuel?? but it is still good trade off.
You don t have a aftermarket EBC.
where do you live? if its in the US, probably not a good idea to be running that ecu on US gas.
why not? US 93 is equal to japan's 98....just different calculations.
Originally posted by Z1 Performance where do you live? if its in the US, probably not a good idea to be running that ecu on US gas. |
I do have a HKS EVC now.
I live in Hong Kong. regarding the octane, Japan 100, Hong Kong 98. I drove my friend home just now and we both thought the car sound and feel a lot more powerful from last night. |
From what I ve been told the Tomei ECU will remove the boost limiter + you have a EVC :confused:
I just set it at 1.3bar because I was told the car can't handle more without mods.
how much was it
around US$450.
The guy said Tomei is more powerful than Ralliart and it could be used with or without a cam mod. The cam will only improve low end torque under 3000 rpm. |
