sheptrans questions and part questions
Im currently rebuilding my evo, the specs are in my sig and I plan on making somewhere around or slightly over 600whp.
I have a 2004 evo 8 I believe its a GSR? it has power windows, locks, etc.. no acd, or any of that stuff though. Does my car have a factory front LSD in the transfercase? and should I just go with the stage 1 shep rebuild if so or is 2/3 worth it? The transmission im only going with standard stuff, as I don't want the 4.11 gears or evo9 first gear. Thanks |
You want the evo9 first and double synchro 5th most def
Originally Posted by tscompusa
(Post 7717442)
Only the 04 RS came with a front LSD. Then every EVO 05 and up got ACD and front LSD
Originally Posted by Force-Fed Performance
(Post 7717448)
Originally Posted by fre
(Post 7717466)
I have an 04 gsr as well and no, they don't have LSDs in the front. I got the standard mitsubishi front LSD from Shep with the bigger bolts in the housing (not sure if that's stage 1). I only make about 520-550whp and 400-420wtq though. I have a friend that is making over 650whp on a 2.3 stroker with a standard 03 evo open front diff and hasn't had any issues with his transfer case, but he knows how to preload his launches well.
My only other concern would then be how strong is the LSD? I don't want to upgrade to something with more chance of failure rate then open diff. |
I'll second the Evo9 1st gear/Input shaft.
Do some thinking about trap speeds and what tires/gear ratio's you want to run... especially if you're limited by rev's (2.3L) I would look into a higher Final Drive... maybe the HKS 4.11 (which I guess is rumored to be an actual OEM mitsu part.) hit me up for contact info on this. |
Originally Posted by gsrboi80
(Post 7717490)
yep mines at shep getting the longer 1st and I was told theres no such thing as the double 5th anymore he just uses one really strong one???
shep stopped doing the dual syncro 5th..
mine car is at sheps right now |
Originally Posted by R/TErnie
(Post 7717658)
Originally Posted by hypnotiq9000
(Post 7717673)
does shep do 3.73's ? those look nice. only 17% increase, which is not bad and just enough. 196mph topend :lol:
my evo started to fall apart at 120mph i can only imagine what it does at 196 haha.... my entire driver side weather stripping fell off. I've yet to replace it. |
I didnt do the 4.11 because I was told that unless your making a real amount of power you are kind of limited by it?
plus I only do DD as well and do a lot of street pulls and not many come close to the top speed of the evo usually its over before that |
