Can't shift into any gear
Sounds like either a hydraulic or clutch issue. First things first make sure your clutch pedal engagement is set properly and bleed your clutch hydraulic system. If that doesn't work, you probably damaged your clutch or maybe partially unclipped your TOB from the pressure plate. Which Exedy clutch do you have? Any vibrations coming through the pedal?
The clutch pedal engagement is good. System not bleed yet though. Clutch is exedy twin plate p/n MM022HD. No vibration if I can remember but I will take a look again this weekend when I have time. I'm surprised that the clutch can go bad just from that one launch...ugh, I'm pissed.
Make sure the TOB hasn't come unseated from the pressure plate clip.
| All times are GMT -7. The time now is 03:43 PM. |
