ACT Lock Out Thread
So with all the talk about ACT having lock-out issues I think its time we clearify this topic. I have read alot of the threads about ACT clutches and it seems to me that the lock out issues happen to the street disc's 90% of the time not the 4 or 6 puck race disc's. So cast your vote!
where is the option for none?
i had an ACT street disk, and it worked great! guess its all up to the install? |
Ok i forgot that option lol. If you have or had a ACT with no problems list which ACT you have or had with a quick review and what mods or hp/tq you have. I have a ACT 6 puck given its on a eclipse but works wonderfull shifting is butter.
Burned through one ACT 6 puck. It shifted great but starting off in first is definitely easier on a stocker or full street disk. No lockout problems whatsoever though. It didn't last long. I'm on a comp stage 3 now and so far so good. I really like the clutch actually.
Intake, Exhaust, & tune approx 300whp. |
yeah man i have the act xtss and i cant shift anything higher than 7500rpm it ****en blows cause i wanna shift at 8k with my springs and retainers and cams but nooooooooo.. if i would have know i would have had a problem like that i wouldnt have bought the clutch..
i have street disk with hd pressure plate... 30k on the clutch, power in sig... lots of roadrace style driving with absolutely ZERO issues at all... i even installed it myself and was my first clutch job ever.. I also never shift higher than 7200rpms
Been there done that in all my dsms and evos...lockout at high rpms= ****ty.
I have an exedy twin HD I can shift at 8700 if I choose to do so with zero lockout problems. |
I had zero issues whatsoever with my street disk and stock flywheel, i got mine from TTP Engineering, very good pricing.
Bout 7.5k and up forget it. HDSS w/over 70k on it. Great street clutch just no high rpm fun
Originally Posted by luckybull
(Post 7784322)
I love my ACT clutch and flywheel combo, I have the street disc/ heavy pp. No lockout issues at all even up to 7500 rpm. When installed the correct way you should have no issues. When this clutch goes out I'll be getting another ACT clutch{thumbup} I'm making 315 whp
the oem clutch disc isnt designed to spin past 7500k rpms so slapping on a beefier (heavier) act disc wont help any bit with lockout. How fast you plan to spin the motor plays a large part in clutch selection! Almost as much as how much power you plan on running.
i had to granny shift my 6 puck at 7000 rpm from 2nd to 3rd and sometimes 3dd to 4th. junk. quatermaster ftw.
i bought my 6 puck sprung from ttp they said they fixed the lockout issue thats why i bought it from them, but i get locked out all the time. i have the bottom motormount as well.
HDSS with a Fidanza lightweight fly wheel
no issues at all all those with issues...if you don't have solid underhood shifter bushings invest in them |
