-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Stripped thread on gearbox - What's the best way to fix? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/463321-stripped-thread-gearbox-whats-best-way-fix.html)
LCS Dec 13, 2009 06:34 PM
When I took of the t/c I found this:
[img=http://imageshack.us/thumbnmail.png]
I'm thinking about machining a larger hole and putting a brass insert in there. What you guys think?
LCS Dec 14, 2009 07:48 PM
:helpme:
Yogi_B Dec 14, 2009 08:42 PM
Helicoil it.
94AWDcoupe Dec 14, 2009 09:00 PM
best way is always the most expensive.
timesert is far better than helicoil but both will work.
so will using longer bolt and a nut (cheapest fix)
or tapping for american fine thread. dont know what works for 12mm upgrade but stripped 10mm can be tapped with 7/16-20 and works perfectly. drawback is you now have an amercan bolt on your car. and you have to enlarge eye as well.
