4G64/MIVEC/FPBlack 1st Impressions
Of note is that this car is completely untuned yet, I flashed my old 92 octane stock 2.0 IX tune into the ECU so I can't yet thrash on the car as it is running way lean resulting in some knock. I can also tell that the MIVEC tables need some major tweeking over the 2.0 map.
The first thing I noticed is the extra off boost torque when driving in traffic, very nice! The 2nd thing I noticed is that the FPBlack is very chatty, the damn thing sounds like a Kenworth truck when driving in the 2500-3500rpm range, throttle modulation in this area results in whistling a turbo tune that is very noticeable from the drivers seat. Did I mention the off boost torque? YES!! it really is a big improvement over the 2.0, I think that Mitsu should have put this block in the EVO instead of the 2.0. I'm running on wastegate pressure (19ish) It looks like initial spool is in the 3800 range (remember the car is still untuned) and I still have the 3" intake and stock MAF. I'm confident that Aaron can get that down into the 34-3500 range that I was expecting with a 2.4. I've still got a few things I need to clean up, When the 2.0 block blew up, a piece of block ended up in the radiator, it punched a small hole in the core. I managed to repair it to get the car running, but I don't trust it! I have already picked up a replacement and will swap it in today. OK, that being said, I can't wait to schedule some time with Aaron and Lucas at English Racing to get the tune dialed in so I can turn the boost up.
Planned for the near future
MIVEC Block Oil Feed http://www.jd-consulting.com/photoga...d=sdwjkpdwgczm MIVEC Head Oil Feed http://www.jd-consulting.com/photoga...d=dmfxtipiffnz http://www.jd-consulting.com/photoga...d=booedcwsckml http://www.jd-consulting.com/photoga...d=uphldkviflgo http://www.jd-consulting.com/photoga...d=uqwhmsxahsqo Next Up: http://www.jd-consulting.com/photoga...d=tbymthppntim |
Nice Johnny...{thumbup}
Cant wait to get it on the dyno. Grab the global (scaling) and drop it down to richen it up some just to be safe. |
Nice looking setup man.
Fathouse |
Originally Posted by Fathouse
(Post 7815133)
Fathouse This setup should be acceptable for my commuter car! John- |
I've had a couple of PM's asking about my setup, I'm running:
Power Enterprise Head Gasket L19 Head Studs The modded MIVEC cam gear details can be found here starting on post# 115: https://www.evolutionm.net/forums/ev...d-build-8.html John- |
Power enterprise HG number- 1001-GM223
Awesome build. For DD I love my MIVEC 2.3 with the FP White. This thing is probably just as fun around town but a pure monster on boost...
Originally Posted by JohnBradley
(Post 7815429)
JohnnyTsi, Thanks and best of luck with your setup {thumbup} 2.4/FP Black = TQ Monster :D |
Someone went to the dyno today for his break in tune :)
Here is a log- http://img.photobucket.com/albums/v5...ohnnyTSI24.jpg I think we can push the 92 tune more still pretty easily, the 1s were VERY intermittent. Boost is a little low for what I think it can do, and I think the S2s might respond to some tuning on the 2.4 that they dont normally seem to like on the 2.0l. I am going to let Johnny post his power numbers though. Keep in mind on a stock turbo with all of his other parts on the stock 2.0 he was 383/355 on a 29psi spike on pumpgas. His car really really really likes boost. The MIVEC was being inconsistent a little (not sure why) and would really help us out and get the boost down to 3800 or so (27psi) or seem to do what it did in this log and linger at high rpm. Also- break in= conservative...this is on the factory knock control settings so the noise might not even be real. |
I really like it!!! That's what I want! What are your HP goals?
What is the part # for the relays used with the Full blown dual pump system? They look real nice. Awesome set-up!!!!!
The relays did not come with the full blown kit.
I've had two of the cheaper 30 amp relays burn up on me so I started using these: They are 12V 75 Amp Bosch Part# 0-332-002-150 Bosch sold their relay division to Tyco which has a different part# V23232-D0001-X001 It is the same relay though, just has a different brand name stamped in the side. John- |
Originally Posted by dambikeracer
(Post 7821480)
John- |
Great build! I'd love to build a 2.4 with MIVEC when my motor goes poop.
Can't wait to see the finished numbers when your issue gets sorted out and you're able to throw some more boost at it on pump and e85. -Jalal |
