question for evo's running high flow cat
are you getting any bad smells for these high flow cats or is everything ok no smell never.
No smell from high flow racing cat.But still getting a cel light.
Originally posted by 3deep No smell from high flow racing cat.But still getting a cel light. |
Are these High-Flow Cats as effective as the stock ones in controlling emissions? In other words, if you replaced the stock cat with a High-Flow one would you still pass emissions testing?
Originally posted by revhappy Are these High-Flow Cats as effective as the stock ones in controlling emissions? In other words, if you replaced the stock cat with a High-Flow one would you still pass emissions testing? Eric |
Originally posted by Eric Lyublinsky If you get the car hot enough you might. FYI the stock car barely passes. :mitsu: had a hell of a time getting it under EPA. I still can't beleve we have only one cat. Eric That's a reason some tof the RX8 guys are claiming for their reduced power, but then again who knows if the engine ever could have put out the previously touted figures. |
I thought the Evo met LEV1 standards this year... how can it barely pass then? BTW running lean is generally cleaner but it increases NO2 emissions, thus causing the cars to fail emissions testing. But across the board you would see lower pollutants in other areas, all things being equal.
Originally posted by nsnguyen I thought the Evo met LEV1 standards this year... how can it barely pass then? BTW running lean is generally cleaner but it increases NO2 emissions, thus causing the cars to fail emissions testing. But across the board you would see lower pollutants in other areas, all things being equal. Eric |
Originally posted by nsnguyen I thought the Evo met LEV1 standards this year... how can it barely pass then? BTW running lean is generally cleaner but it increases NO2 emissions, thus causing the cars to fail emissions testing. But across the board you would see lower pollutants in other areas, all things being equal. |
Quote from a spec page:
"Evolution VIII is powered by Mitsubishi's 4G63-type 2.0-liter in-line 4-cylinder DOHC intercooler-turbocharged engine which conforms to Californian LEV1-LEV emission regulations and has been specially tuned for gasoline octane numbers used in the U.S. " |
You can get some of this information on the EPA site:
http://www.fueleconomy.gov/feg/findacar.htm The EVO is not THAT bad in this area: Air Pollution Scale 0 (Least)-10 (Most) EVO = 6 S2K = 6 (03) 350Z = 6 STI = N/A RX8 = N/A Greenhouse Gases 0-15 tons/yr. EVO = 9.0 STI = 9.5 S2K = 8.7 (04), 8.4 (03) 350Z = 8.5 RX8 = 9.3 |
I don't notice a smell, but I have a CEL so I would not pass emissions in Texas right now. Ryan Fellows at RnR is working with me to get this fixed though, we might have to go to a Random or Carsound cat instead of the Catco. I have had the car two months and it is my first new car, I am NOT going to put up with a CEL and I do not want to revert to a CEL eliminator when I don't have too.
On the site, it says 10 is the best, 0 is the worst. So then the Evo is actually decent. I wonder what cars qualifies at 0??
Originally posted by revhappy You can get some of this information on the EPA site: http://www.fueleconomy.gov/feg/findacar.htm The EVO is not THAT bad in this area: Air Pollution Scale 0 (Least)-10 (Most) EVO = 6 |
Originally posted by jansolo On the site, it says 10 is the best, 0 is the worst. So then the Evo is actually decent. I wonder what cars qualifies at 0?? 0( worst) - 10 (best) There are some versions of the Civic Hybrid that get a 10 (California I presume?). Interestingly the regular Civic only got a rating of 7-8. |
Originally posted by jansolo On the site, it says 10 is the best, 0 is the worst. So then the Evo is actually decent. I wonder what cars qualifies at 0?? I don't think we have enough info to say that the EVO's rating of 6 is decent, even on a one to ten scale (10 being the best) until we look at where other cars are on the rating scale as well. It the rating of 6 was one of the lowest of cars in the market, and most cars had a rating of 8 or 9, then "decent" probably isn't the word you'd be looking for. |
| All times are GMT -7. The time now is 03:20 AM. |
