-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Aussie's got 10.8 hotsides now (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/471347-aussies-got-10-8-hotsides-now.html)
nudge120 Jan 30, 2010 05:22 AM
I though of you might find this interesting, found this on a AU evo forum:
http://www.meek.com.au/index.php?act...&productId=384
"These fantastic new turbine housings feature super enlarged wastegate ports GTpumps flow bench tested at 31% more than 10.5cm EVO9!!!"
I'm sure this would be a big upgrade for VIII turbos, but what do you think it would do for a IX turbo??
Viciouslord Jan 30, 2010 05:27 AM
good find!
eve-slow Jan 30, 2010 05:29 AM
If it flows 31% more than the EVO9, I bet we all know what it will do for an IX turbo.
06MREvo Jan 30, 2010 05:31 AM
Damn...thats pretty badass...I am looking forward to someone testing 1 of these...
EvoLutionized8 Jan 30, 2010 05:43 AM
A third more flow hunh.. yeah, gotta see some flow dynamics to understand the math on that one. all the FP stock appearing owners out there would probably be very interested if it produces as advertised.
Freddy302 Jan 30, 2010 05:47 AM
Exactly!! If this works right in the real world.. Every Black owner would need one! If it doesn't loose spool on the Red or Green it would be a Huge Plus!
bbyevo8u Jan 30, 2010 06:09 AM
wow i'm interested! anyone running this 10.8 hotside
Steve93Talon Jan 30, 2010 06:38 AM
Anyone who knows FP's history with DSMs would tell you that it'll only be a matter of time before FP casts their own proprietary turbine housing for the EVOs. When they do, I guarantee it won't be a stock clone with a slightly larger scroll like this one appears to be.
ripnbst Jan 30, 2010 07:46 AM
So I wonder what this is competing with the Black or the red.
bbyevo8u Jan 30, 2010 07:50 AM
i want to buy it but what country is that vendor from?
do any evom vendors have this?
03whitegsr Jan 30, 2010 03:28 PM
HAHAHAHAHAHAHAHHA You've got to be kidding me.
The cast in part number is the same as the 10.5.
They have ground of the 10.5 part and scribed in 10.8 though.
I wonder if some neon back lighting to the photo would bring their flow bench numbers up another 30%.
ak47po Jan 30, 2010 03:35 PM
Probably just been ported.:lol:
Evoryder Jan 30, 2010 03:54 PM
That's funny.
nudge120 Jan 30, 2010 04:45 PM
I reread the post, my mistake it is the wastegate ports that flow 31% more. I'll correct this in my original post. More info from the vendor.
"On a car with mild mods it will give similar performance to the 10.5cm (eg. much better performance over 6000RPM), on a more modified car (cams, 1.5 bar boost, etc) your can really take advantage of the extra airflow. Spool is not much different to a 10.5cm. So if you have a 9.0cm or a 9.8cm this is a big upgrade.
This housing is also ideal if you are running a stock turbo with a stroker. "
Q: is this pretty much same as a ported 10.5?
A: "No it's a complete new casting"
06MREvo Jan 30, 2010 04:53 PM
^^^interesting...like I said...looking forward to someone testing it...
