-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Anyone here replace the Oil filter housing? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/485559-anyone-here-replace-oil-filter-housing.html)
MR. EVO MR Apr 10, 2010 08:30 AM
can someone here that replaced the oil filter housing give me any pointers that i should be aware of?
mine is cracked and i just want to make sure that i install the new one correctly.
Thanks for any positive info {thumbup}
JohnBradley Apr 10, 2010 08:59 AM
Make sure the gasket surface is clean and then go. A couple of bolts and you are done.
MR. EVO MR Apr 10, 2010 02:12 PM
John
thank you for responding
Is a new gasket necessary? Or can I reuse the ole one?
05 EVO 32k miles
thanks
irishone337 Apr 10, 2010 02:43 PM
Get a new gasket when you buy the housing. I'm pretty sure the oil thermostat is in the housing too so you may need to transfer that to the new part. Also, be sure to get new crush washers for the banjo bolts that to to the oil cooler lines. It's literally three bolts that hold it on, and two big 22mm bolts for the oil cooler.
MR. EVO MR Apr 11, 2010 01:22 AM
Thanks for the response, I'm buying that stuff tomorrow then
MR. EVO MR Apr 13, 2010 03:28 AM
just got the new housing yesterday
does anyone know the tq specs on the bolts?
RunThat Apr 13, 2010 03:43 AM
19 ± 3 N·m
14 ± 2 ft-lb
MR. EVO MR Apr 15, 2010 01:10 PM
Originally Posted by RunThat (Post 8194061)
19 ± 3 N·m
14 ± 2 ft-lb
Thankx everyone for the reply :beer:
MR. EVO MR May 6, 2010 03:23 AM
I just started yesterday trying to remove it, I found one bolt on passenger side, it got loose but doesnt come out. How do I remove it and where is the other bolt?
im thinking to get her towed to my Mechanic...
MR. EVO MR Aug 3, 2010 03:16 AM
she was towed, not a ramp project for me.
