-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Car won't start. 12.5+ volts. Pump kicks on. Starter? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/488911-car-wont-start-12-5-volts-pump-kicks-starter.html)
Jk's03EVO Apr 26, 2010 06:54 PM
This car has been a pain on and off electrically since I bought it. I changed the battery. It worked good for a while. Then started again. Then stopped. Now it's doing it again. Car charges at 14.2 until it warms up a bit then its no less than 13.9 unless I use the windows then it will drop. I do have the battery in the trunk. Everything is solid connection wise with a killswitch and 2 gauge wire running to the engine bay. I even killed the battery and it wont start thinking maybe there is a draw. Nothing. It will start fine with a jump that's what's getting me.
So I am narrowing it down to the starter solenoid, the clutches, it not engaging the flywheel, the relays on the firewall or something similar.
Anybody have any thoughts?
STWHY? Apr 27, 2010 01:27 AM
That sucks aaron..Hope you get it worked out....GL man..
Jk's03EVO Apr 27, 2010 02:47 AM
I have the Taylor kit too and I like it but if I swap the starters and relays and nothing happens the battery might go back to the bay.
sleepy_rps13 Apr 27, 2010 03:26 AM
Do you have an aftermarket alarm? The reason I ask is because I have a somewhat similar problem with mine also. Sometimes my car just doesn't want to start at all (doesn't even crank). Battery is fully charged and everything works fine. It went on for about half a year and the whole time I thought it was the relays, starter, etc. But, I recently noticed something by accident that seems to have helped me figure out the source of the problem. Apparently the previous owner of the car had installed the alarm himself, and the wiring is not the most beautiful or the best in the world. Lately, whenever my car acts up and doesn't want to crank, I just wiggle a certain wire by the driver's side kick panel that was spliced into for the alarm and it cranks and starts up right away. So I'm guessing that wire has to do with the starter kill or something related to it. This has worked every time so far.
Liqquid Apr 27, 2010 05:19 AM
I had similar issue, but it was predictable. When cold, starter would not crank fast enough to start engine on first couple tries which leads to the battery going dead... but with a jump (cables hooked up front) it started right up. Replaced stock battery with 1000/800 duralast and connected ground cable (from Taylor kit) to drivers side rear seat belt bolt, SCRAPE THE PAINT first... car starting great now.
If you had not scraped the paint down to bare metal where the ground is connected, do so and see how it works out... I've never HAD to actually do that to have successful grounds in the past but this one seems to have helped, car cranks over much faster now.
JakeTheVIII Apr 27, 2010 05:59 AM
Check cam angle sensors and the grounds for it
Jk's03EVO Apr 27, 2010 08:21 AM
Would the CAS not start the car until hooked up to higher than normal voltage? That's kind of why I wouldn't suspect it but I will look. I will also change the ground again and see if that helps. And if all else buy a monster battery with crazy CA.
Jk's03EVO Apr 27, 2010 08:22 AM
Oh and thanks for the thoughts. I will try everything.
Fast_Freddie Apr 27, 2010 08:46 AM
Damn Aron, look in the For Sale section, there is a good complete 05 harness for $125 shipped... get it and lets get a mini battery in the engine bay...
20gmr Apr 27, 2010 09:14 AM
is it even cranking when it doesn't want to start. cranking slow???? do you hear the solenoid click as if its a dead battery. do you turn the key and nothing happens except maybe a small click?? please be more descriptive.
Starter circuit draws a huge amount of amperage so make sure those connections are quality and also look at the main power connection to the starter, that could be loose. You could also try unplugging you clutch switch, never saw one go bad but hey its possible.
Jk's03EVO Apr 27, 2010 04:29 PM
Car does not turn at all, starter does not engage, and just one click. Which I think is the starter relay on the firewall.
mifesto Apr 27, 2010 04:39 PM
sounds like your starter isnt grounded well. this happened to my 94 supra, it would just CLICK and not start but would start fine once jumped. starter had ground but it wasnt good connection so it had insufficient power going to it. once i cleaned the connection thoroughly, all issue was resolved.
mattz09 Apr 27, 2010 05:34 PM
+1
check all your grounds. clean them all to make better connections. make sure were it is grounded on all your grounds its not rusted to hell good luck man!
Jk's03EVO Apr 27, 2010 06:08 PM
Absolutely right I hope. Started messing around with the wires at the starter since I was thinking that it was the starter. Well one of the wires was loose as in I felt it when I wiggled the wire. It's the forward most one which is the power wire since it all made a lot more sense after the car popped right off with 12.6v. Shut it off. 12.7v. As far as this wire not being a good connection. The battery was charged sending good amps through the wire but since the connection wasn't great the relay or solenoid just clicked. But since jumping the car is pretty much 1 1/2 times the power it sent the right voltage through whatever crappy connection and/or arked across the gap.
Now I don't want to bite my tongue but I am hoping for the best tomorrow morning. I'll keep this thread updated on the results.
Ted B May 1, 2010 01:43 PM
Be sure to update this discussion. I am dealing with the same issue. I have verified that it isn't the battery, battery connections, starter, starter solenoid, starter switch in the steering column, or starter relay. Like you, occasionally I get nothing but fuel pumps running - no starter activity.
I also have an alarm system, so I'll have to consider that.
I didn't see anything wrong with the starter connections at a glance, but may have to go back and recheck.
