Recomendations on spark plugs for my evo ix
hey wats up i need to change my spark plugs but i dont know which ones to go with wat do you guys recommend?
stock iridium unless you're making an assload more power.
I'm only doing 330whp
I'm in the same power range, I use the OEM plugs.
OEM plugs are over $65/set. I use NGK Iridium IX, BPR7EIX. As good or better than OEM and $28/set at Kragen.
Stock...
Originally Posted by lbcevo
(Post 8284348)
The OEM Iridium IX plugs are $47 per set here by the way..... http://www.maperformance.com/evo-vii...ts/index2.html |
Originally Posted by GG06MR
(Post 8285896)
You have an VIII, and he appears to have a IX, so the BPR's won't work for him.
The OEM Iridium IX plugs are $47 per set here by the way..... http://www.maperformance.com/evo-vii...ts/index2.html http://www.lancershop.com/customer/p...5&cat=0&page=1 |
Originally Posted by bbyevo8u
(Post 8285957)
those are not oem ix plugs!!!
Here's a link to the exact listing of the plugs: http://www.maperformance.com/ngk-las...7h-evo-ix.html They may be out of them, but the ILFR7H's are the OEM IX plugs. |
(Post 8286006)
Sorry, I assumed you'd scroll down to this listing: "NGK Laser Iridium Spark Plugs / Heat Range 7 (ILFR7H / Evo IX)"
(Post 8286034)
umm those are NOT oem plugs!
https://www.evolutionm.net/forums/ev...ead-plugs.html |
(Post 8286034)
ok i was looking at the part # Genuine/OE Mitsubishi Part No: 1822A022 from mits web site, i see the item # is ILFR7H so i stand corrected, it threw me off cause of the american box with diff part # different from the japanese mits box but i think your rite they are the same
http://www.google.com/url?sa=t&sourc...urmrbtMjlJzPcw |
(Post 8286085)
http://www.rallysportdirect.com/shop...gs-p-3662.html http://www.amazon.com/NGK-ILFR7H-Las.../dp/B000HDH19I http://www.turbowholesale.com/produc...productid=9091 |
+1 Stock Iridiums (ILFR7H), unless you are making a boat load of power and running hot, then consider the step colder plugs.
