Lsd Conversion
hello guys,
was told that changing my jdm evo 8 mr Lds (which comes with ACD) , with a udm RS (NON-ACD) would be good idea as its stronger? as i only do drags which as u all kno involve launches, and even if i do decide to go for the conversion can u please tell me what would be removed i.e acd pump lines etc? will the ACD 3 lights all lite up? as the scd system is deleted. is the udm non acd RS Lsd stonger then the jdm MR Lsd? sorry to be such a pain.:o thanks . |
Any body?
You'd have to remove the following:
ACD ECU (may still need to keep this due to ABS sensors) ACD hard lines ACD pump and you'd have to plug the hole on the ACD t-case where the hard line connects. Btw, I am selling a BRAND NEW non-ACD LSD. Check my thread in the for sale section. Have pics. |
so is the udm non acd RS Lsd stonger then the jdm MR Lsd?
will this conversion help me in drags??? |
From everything I understand, yes, the USDM RS diff is better and should def outlast the JDM ACD one at the track.
ok guys thanks
