woah...to much to read!!!...
do you have stock snorkel?...if so make sure clips are still in... |
From reading the car is untuned correct?? If its not tuned no worries
It could be an issue with that front O2 thats in there. It sounds like the ECU doesn't have a clue how to fuel the car. Only time I have ever seen a P0125 was due to a tuning issue |
Originally Posted by sharkm87
(Post 8415730)
do you have stock snorkel?...if so make sure clips are still in... Have stock snorkel and clips are in. |
Woah what did you gap your plugs at?! 0.55mm I would double check that against whatthe guys on this site do. I could DEF. be wrong, but I don't think that's right.
Originally Posted by gsrboi80
(Post 8415744)
It could be an issue with that front O2 thats in there. It sounds like the ECU doesn't have a clue how to fuel the car. Only time I have ever seen a P0125 was due to a tuning issue When I got the P0170 with my OEM O2 sensor the car was running rich and had loss of power.Replaced it and fuel economy went up by half and car felt more powerfull. Now it looks the other way around and way to lean.Going to measure both front and rear O2 tomorrow. |
Originally Posted by MicRX
(Post 8415756)
Most people on here seem to run between 0.024-0.028",NGK.com even says 0.032" but on NGK.de it says between 0.5-0.6mm so I don't know if I should regap them or not?Running 98 octane here. |
O ok no you seem like your running with the right gap then. Just a different way of saying the same thing.
boost leak test?
(Post 8415792)
boost leak test?
Probably way to little to spot any leaks.Going to get me some stuff to make a decent one. What's the stock boost on a IX? |
i belive 19psi..but yea 9 psi is way to low especially if leakin from the tester...
that'll be a great place to start |
My car ran poorly when i swapped to a new intake pipe and filter. It was a perrin also, thought it would be ok because of what I was told but that was not the case. Th car ran very poorly i did much of what you did. It stalled, needed a lot of gas was very finnicky etc. I switched back and it took the car a little while to adapt. But if you don't have a tune I wouldn't be worried. Your car won't like an intake unless it's tuned specifically for it.
check both coolant temp sensors on the throttle body. I am willing to bet this is whats wrong. Do you have a buddy that you could try his quick? or access to someone with evoscan who can see live data of what the coolant sensors are reading.
Double check your front o2 sensor connections. I had one where it was literally just enough to get the sensor to activate but it would randomly go rich or lean because engine vibration would cut and reengage the connection randomly.
Originally Posted by mrdevo
(Post 8416392)
Originally Posted by 20gmr
(Post 8416941)
If I could just switch out parts it would make it alot easier to find the problem. I have Evoscan but don't have a proper cable.
Originally Posted by RoadSpike
(Post 8417118)
| All times are GMT -7. The time now is 01:44 PM. |
