-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Intercoolers (evo4-9): weight's?, temps in/out, hp gain vs stock?? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/502299-intercoolers-evo4-9-weights-temps-out-hp-gain-vs-stock.html)
racemc Jul 8, 2010 11:36 AM
First sorry my bad english...
Questions:
- The cooling capacities vs stock (evo 4-9?). in/out temps, any link to results?
*Will be used +500 hp race car with about 1.8 bar/26 psi boost. ..want real "dyno or race" test results. This is real interesting if someone has real results!
- Gain (about hp) vs stock
Hard to find real results!
*...so want real dyno result with 500 hp car with upgraded intercooler vs stock.
- Different intercooler's (3,5") weight?
*Interesting information as it will installed in a racing car.
Also manufactors may answer (if real results)!
ETS, Buschur, AMS, Turbo xs, Nisei Engineering etc..
ETS Michael Jul 8, 2010 01:56 PM
Reserved
turbolarry Jul 9, 2010 06:52 AM
It is going to be extememly difficult to find all of those results if they even exist and the stock intercooler will never support 500 hp.
What kind of race car; drag or road?
1.8 bar/26 psi, but out of what turbo?
If you are really concerned about weight, then a bar and plate application souldn't even be considered.
This place put out some info on heat rejection vs. stock and pressure drop. They use a Griffin core.
Good luck.
http://www.xs-engineering.com/xsstor...idproduct=1893
http://www.roadraceengineering.com/e...flowcharts.htm
racemc Jul 9, 2010 08:24 AM
Good luck.
- rally/hillclimb... kind of...
- Car has stock intercooler and +500 hp, pulls max torque about 4000 rpm (tested in 3 different dynos)
- Custom made turbocharger
- Shell race fuel (Turbo Rally - FIA regulations)
..but thanks to links
RSMike Jul 9, 2010 02:57 PM
erm how can pressure drop decrease with an increase in flow... surely thats flawed testing?
leonevox Jul 9, 2010 03:04 PM
a 3.5" and an 5" weight about the same. You not going any faster with a lighter 3.5" cooler
racemc Jul 9, 2010 04:35 PM
This a ll is now off topic! {offtopic}
When you want improved front/rear weight distribution everything counts(gram or kilogram).
- We don' t need 4-5" intercooler because we now that 530-560 hp is enough. Much more important is that the engine operating wide range. Starting spool 4500 rpm, +600 hp engine sucks.
All we wan't know can we get engine temps down (or) more power
* how much (5 or 50 hp...exaggerated).
turbolarry Jul 10, 2010 06:21 AM
Holy sh!t! 500 with a stock intercooler! :eek: Those things flow like crap when you are moving that much air. You can throw in just about anything and you are going to see gains.
leonevox Jul 10, 2010 07:57 AM
^LOL 500whp with stock IC
