-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Should I switch to S3's? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/518217-should-i-switch-s3s.html)
Svendiesel Oct 6, 2010 04:20 PM
This isnt so much a "help convince me" thread moreso than it is, technically, is it doable type question? I have S2's right now, its a BR long rod 2.4 (10:1 cr) with an FP Black and a BR stage 3 head. I want to do the S3's because theyll help the motor breathe a little better especially up top.4 and I feel like theyll push me an additional 25-40whp past where I am now. My biggest concern is piston to valve clearance.
Anyone have any input?
oofastlineoo69 Oct 7, 2010 04:47 AM
i belive youll be fine.. have them in my 2.1 br motor ill let you know how they are in like two weeks...
FathouseFab Oct 7, 2010 06:18 AM
Are you a 9? I would run the custom Cams John Bradly had gsc make.
I would not throw any big cam in without checking ptv clearance though.
Fathouse
n2oiroc Oct 7, 2010 09:27 AM
Call greg@gsc. Something custom may be best.
oofastlineoo69 Oct 7, 2010 11:10 AM
Fathouse
Fathouse what do you mean?
bbyevo8u Oct 7, 2010 11:31 AM
why didnt you go with the BR cams?
JohnBradley Oct 7, 2010 01:56 PM
Its an Evo IX, there is no option from BR for those currently.
The custom cams we have done are hard to get billets for. Greg and I have talked about running S3s in my car to see what the difference is. However we just havent had a chance to get that testing done yet. The lift on the S3 is 11.7 both sides so its a little less than the crazy ones I am running. I think this would be a more accessible easier to obtain route.
It would require going to a specific valvespring for the combination though. Either the GSC spring with Ti retainer or a set of Kiggly Valvesprings.
Aaron
oofastlineoo69 Oct 7, 2010 01:58 PM
Aaron
so the gsc s3 for the evo9 from gsc are what specs... and what are the specs for your and the price?
thanks rogerio
JohnBradley Oct 7, 2010 02:06 PM
My specs are not being disclosed publicly other than they are bigger than an S2 and have 12mm of lift. As we can get them they are 685 a set. The GSC S3 cams are these specs-
S3 Specs .
6009S3 ADV Duration Duration @ 1mm Peak Lift CenterLine
Intake 280.........................................238 11.70mm 130
Exhaust 280......................................238 11.70mm 115
Svendiesel Oct 7, 2010 02:08 PM
Ya I did think about the custom cams and spoke with Greg and Aaron at one point on them, and I then kind of swayed over to the S3's due to the fact that theyre a little more user friendly than the custom grind ones and the S3's are a bit more readily available than the custom grinds.
oofastlineoo69 Oct 7, 2010 03:57 PM
yea i would just go with the s3s or fp5rs ...
FathouseFab Oct 7, 2010 04:39 PM
FP5rs are bigger than the s3 cams I belive. I run those in my setup now, nasty they are!
Fathouse
oofastlineoo69 Oct 7, 2010 04:45 PM
Fathouse
i know i would run those if i could sell mine...
Svendiesel Oct 8, 2010 02:01 PM
5R's would be interesting, I think theyd do well for the 2.4, the extra breathability would be good.
toysgetsmoked Oct 8, 2010 03:37 PM
Actually to say the truth i'm not impressed with my s2 cams that much if I had my choice I would have gotten the kelfords are even wait for the juns..If I was you get the fp5 cams.
