-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Car won't fire (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/518227-car-wont-fire.html)
birdhead Oct 6, 2010 05:40 PM
Car won't fire
We just put a new head gasket and headstuds in. We are getting fuel but won't fire we put net coils on it still no. It's weird the engine is timed right too. Please help o it is 2.3 strocker with a gt42r turbo and it has aem ecu
MRolla Oct 6, 2010 06:21 PM
cam sensor reading? is the crank reading the reluctor ring, reluctor ring installed. are you getting sprak?. are all fuses good?
Force-Fed Performance Oct 6, 2010 06:31 PM
you may need to provide a lil more information so people can help or give advice buddy.
Have to tested compression, was the car running fine before? Was the head re-surfaced before it was installed?
signature sound Oct 6, 2010 08:42 PM
make sure the crank position sensor plate is on in the right direction. flipping it 180* could cause this.
birdhead Oct 6, 2010 10:16 PM
Yea every thing is on right the car was running before
EvoVIII808 Oct 7, 2010 12:04 AM
Fuses, CAS, and was this a plug n play EMS or universal? Could have some wires mixed up if universal.
birdhead Oct 7, 2010 11:09 AM
It's a plug in play the cas is good I have checked everything
05VIII Oct 7, 2010 12:46 PM
You checked everything? Obviously not if it still won't start. Go back and check fuses and sensors, one has to be bad.
EvoVIII808 Oct 7, 2010 02:08 PM
Not sure if the Question of Are you getting spark was answered.
Need to pull those plugs/coils and check. Car Ran fine before a head swap, there has to be a connection not connected or blown fuse somewhere.
birdhead Oct 7, 2010 03:32 PM
I've checked the fuses again connectors I even changed plugs and coils to
NJ_EveOhVIII Oct 7, 2010 05:37 PM
prob some ground you missed or a little sensor.
or its just your car being mad at you that it will only be in full boost for maybe 2k rpm.
EvoVIII808 Oct 7, 2010 05:55 PM
lol.
JonDSM Oct 9, 2010 08:31 PM
Is the check engine light on? can you scan it and just have the computer tell you what's wrong?
Do you have a test lead to hook up a timing light and check your ignition timing?
Are all your grounds hooked up?
gieri002 Oct 26, 2010 01:58 PM
Are you sure the oil pump pulley is not rotated 180 degrees?
Did it run before?
