Post your Synapse DV config and results
This is for the small Synapse DV and not the big Synapse BOV.
I've been running mine for two weeks in push mode with port B connected to manifold and spring preload set to the factory value (min preload). I am getting a bit of DV flutter at ~4-7 psi when lifting the throttle slightly to stabilize speed in 4th-6th gear. The flutter is about the same as what I got on my unmodded IX DV; it just occurs at slightly higher boost than with the stock DV. Seems like the flutter has diminished over the last few days. Could be that its breaking in slightly. Considering that the flutter is no worse than stock, but it will hold 60 psi, this config works as good or better than any other DV people have mentioned on EvoM (perhaps the APS valve peformed better for some people), and it meets my expectations for an aftermarket DV. However, I'm going to test a few more configs to see if I can get it working even better. aby@mil.spec has a good pull mode config, and I will be trying that next weekend. I will probably also try port A in push mode. |
Good info! Keep us updated, I'm about to buy one.
Originally Posted by Foxmaster
(Post 8823143)
Could you post a pic of it installed? I'm about to buy one of these and was wondering about fitment.
Thanks, I just found some more threads on this looks to be a very promising piece.
I just installed mine lastnight with both a&b ports connected by the y then onto my im, I have it set in pull mode. Having surge issues, but it was late lastnight and didnt get mess with it at all.
subscribed, anxiously been awaiting real world results and info from members keep it coming {thumbup}
Originally Posted by boosted91t
(Post 8823275)
The original Synapse DV (the big one) can be installed in a 'pull' config because of the C port. I'm most likely going to get rid of my big Synapse DV and switch to this smaller one as I am moving to CA and just want one less thing to worry about. I wish they had this smaller one when I bought the original. The orignal works awesome...it's just too damn big. :) |
Just ordered mine, I'll post my impressions when I get it!
I had the same problem, but it went away after I installed a different spring. It's a little softer, so the piston is able to contract more more.
I am running 1 full turn of preload after unscrewing it all the way out. I forgot to mention I am running "pull" mode and have it hooked up to only port A with a small breather on port B. |
my favorite is pull mode, a-port (closest to the adjusting screw), zero preload with the factory spring.
I tried push mode with an experimental spring & the boost response during wot wasnt as good for me..... i tried both in a only & b only, not with them t'd together. with the experimental spring, pull mode is best so far in a-port & some preload....more details later.....this spring dramaticaly reduces fwy on-throttle flutter!! |
I would try removing the spring altogether. I have run my "big" chronic that way and like it.
I will be flipping my valve around once the weather clears up and post some results. Again I am at 26-28 psi on a bbk and the surge is somewhat violent when you lift. But I installed it last minute and it is setup in pull mode. I will be flipping it and hopefully I can get some good info for you guys. Excellent valve so far!
On Evo 8 mine is in push mode A+B connect stock preload settings, working near perfect. Only issue on highway goes up on the hill with 80-100mph and just holding the speed or playing with the gas pedal i have some flutter. anyway seems like it is working.
Just installed mine in Pull mode, with AB connected. Everything is working great, except I'm getting some surge in 4th gear at lower rpms. I'll post some more impressions once I get more time and testing with this DV.
After spending the day in AB Pull mode here are my impressions...
I can get surge in 2-5 if I use 1/4 throttle to accelerate from 3500 and up. Valve easily blows off low boost 10 and under with little to no fluttering. Car feels more snappy/spools faster and smooth versus the old crushed 9 valve. I'll be trying different combos over the next couple weeks to see how they feel. |
