-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Loosing power. What's wrong? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/526797-loosing-power-whats-wrong.html)
Billy05MR Nov 25, 2010 05:02 PM
I have an 05. It drives fine under normal cruising conditions but when i get into it it will builg boost up to 8 psi and then it will loose all power. it holds the 8 psi. And it builds the boost very quickly like normal. I dont think its a boost leak. could it be the MAF or a bad spark plug or coil pack? I have full exhaust, exhaust manifold, uicp, licp, intercooler, intake, and an aem truboost boost controller. Any ideas?
monkey_187 Nov 25, 2010 05:10 PM
Are you tuned with your current mods? Have you done a boost leak test? I would check the basic s**t first.
evo unknown Nov 25, 2010 05:28 PM
+1..is the car tuned?
Billy05MR Nov 25, 2010 09:48 PM
No not tuned but ive been running the car with all the parts in for the past 3 months and nothing went wrong until now.
EVO(boss) Nov 26, 2010 12:32 AM
boost leak or MAF
3dcalixpress Nov 26, 2010 01:28 AM
maybe your solenoid went bad on the tru boost ...was it new or used ?
Billy05MR Nov 26, 2010 02:35 PM
It was brand new. If it was the MAF would it throw a CEL?
BOOSTIN24 Nov 26, 2010 04:54 PM
I had a similar problem, for me it was my intake, but if its not that it could also be your wastegate if its still the stock one
4g63Moon Nov 26, 2010 05:15 PM
What kind of bov do you have? And did you check all the pipings for leaks?
Billy05MR Nov 26, 2010 08:43 PM
I'm running the factory recirc. valve. What would be wrong with the wastegate?
Billy05MR Nov 26, 2010 08:44 PM
And what was wrong with your intake?
