MAF Cleaning...CRC MAF Cleaner
So i did some searches on using this product here and most are old but most have said they used with success at the time.
I noticed on the back of the can that the directions state not to use the product with mitsubishi's (see below). However they do not speficy which mitsubishi models so my question is does the evo (i have an 05) have a Karman-Vortex airflow sensor? "10. DO NOT use on vehicles with a Karman-Vortex air flow sensor, e.g. Toyota Supra Turbos, Mitsubishi’s and most Lexus vehicles." http://www.crcindustries.com/faxdocs...on/st05110.pdf |
well if ur gonna risk it....go ahead...personally you shuold be alright with the mass air flow sensor, main thing you gotta be careful about sprayin is this little red metal part in the flow sensor thats your heater to help the maf determine a/f ratio for the ecu...if you spray it get yourself and air compressor and air nozzle and spray out inside of the maf immediately after you spray it...good luck and remember its a couple hundred dollar part haha
I have used it multiple times on my 05 evo without any problems.
ive used it on mine with no problems what so ever
Been Using it for years now. Never an issue
I too have used a couple times with no issues. It worked great for me each time.
using an electrical cleaner with no issue
don't use the nozzle on the parts in the middle, use the open spray pattern when clenaing those pieces also clean when maf is cold |
i have used it multiple times as well before i went SD without any issues.
Used it, on a few evo's, no issues.
excellent thanks guys.
Used many times with no issues.
I used it a few times with no issues. I didnt use the straw because I didnt want to concentrate the pressure on any small piece that might break. A good idea as said above to clean it when its cold. The spray comes out pretty cool and if the maf is warm the temp difference might cause something to crack.
just dont spray point-blank... besides that i've used it myself several times a-ok
I swear by it,good stuff.
I'll pig-pile on here...been using it for a while with no issues :mitsu:
