-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Fuel pump won't turn off? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/529839-fuel-pump-wont-turn-off.html)
Steven Dec 15, 2010 02:38 PM
I bought a car last weekend from Florida that has a Buschur double pump setup in it installed by AWDMotorsports. My wife called me at work this morning and said the car was making a weird noise but was off. I came home and found that the fuel pumps were running. I pulled the fuse from the wire attached to the battery (wired to the fuel pumps) and they turned off. I won't have time to look at the car until the weekend but figured I'd check to see if anyone has seen this before. Any ideas?
ROGERV Dec 15, 2010 03:23 PM
Hobbs switch might be stuck in the on position. I had the same problem, ended up buying a replacement from Napa.
Steven Dec 15, 2010 07:09 PM
Thanks!!! I just got home and followed the power wire off the battery all the way to the hobbs switch. Sure enough, it was severely corroded. I hooked the power back up to it and the fuel pump turned on. I then flicked the switch with my finger and no more fuel pump. The installer did a good job hiding it and I would have spent hours trying to figure it out. I really appreciate your help.
