Where's this *&%$ thing go?
I already had to doa lot of work because the car I bought seemed ok then I got some crazy stuff going on and after some investigation and diagnosis of my FP Red, she was done. So I'm taking things out and apart and I notice a hose that I had no idea where it was SUPPOSED to be connected to. I'm assuming the TB but it wasn't connected. Can someone tell me where it's supposed to go to.
http://i32.photobucket.com/albums/d4...1/DSC01994.jpg http://i32.photobucket.com/albums/d4...1/DSC01995.jpg |
That's the fuel vapor purge valve hose. Goes to I/M
it could be there unconnected because someone did a evap/charcoal canister delete..if this is the case they capped the inlet nipple for this on the manifold..if not you prob had a bad vacuum leak didn't you.
thanks, now I just have to figure out which nipple it goes to. Also, why don't I have any hoses hooked up to my TB?
vac at idle has been around - 13 and everything seemed ok
if you dont have EGR/evap crap in your car it does nothing, you can just take it off. i leave mine uncapped and just let it vent
Here is a thread about that mod.
https://www.evolutionm.net/forums/ev...-canister.html Just make sure, if you are using the OEM intake manifold, CAP the end in the IM. (leave the line in your picture vented, don't cap it) |
TB nipples are for coolant. Leave those capped off unless you live in negative temperature climate year round
I'm new Evo's and different mods (even DSM) so I'm still learning but I appreciate all the help so far.
| All times are GMT -7. The time now is 01:33 PM. |
