Cam Specs Thread - Updated
5 Attachment(s)
Below is a list of all the popular aftermarket Evo VIII & IX cams w/ published specs. If there are any other cams that you have the specs for let me know and I'll add them. Evo IX cam specs are in the post below this one. Hope this helps {thumbup}
*FP cams advertised duration is for .050" (1.27mm) and not 1mm* EVO VIII Cam Specs Attachment 289632 Attachment 289633 Attachment 289634 Attachment 289635 Attachment 289636 |
3 Attachment(s)
Evo IX Cam Specs
*FP cams advertised duration is for .050" (1.27mm) and not 1mm* Attachment 289629 Attachment 289630 Attachment 289631 |
This is very helpful in looking at cam spec.
Thanks for taking the time to do this. Helps a lot since I will be changing cams sometime this summer. I know someone that might have some gsc s2s for sale soon. Might have to buy them after seeing this. :D
Very good info , thanks man
Added a bunch more, going to see if the mods will replace the current sticky w/ this.
Added IX specs
Great update, good to see the new hks 272/278 up there for the IX. Quick question, how does duration of cams affect power band and agressiveness/driveability? ie. kelford 272/272 and the new hks 272/278, more duration for hks but similar lift. What would be the difference between the 2 when installed? Stock IX turbo in my case...
I ordered gsc 280 cams for my car. I plan on going with a fp black turbo do you think these cams were a good choice? I got them for a really good deal so let me know
cosworth M2 for mivec engines 272 advertised, 255 intake, 221 exhaust;)
Is there any more info on the tomei 270 11.5mm lift as I have a set at the moment I'm fitting into my new 2.4 motor and need to know at what degree to set the max Lift of the cams to???
Great info, thank you!
Found the info i needed in the end for the tomei 270 procams for hydraulic lifters with 11.5mm lift.
Centreline for intake is 110 Centreline for exhaust is 115 is the OP can add the info to the chart. |
Good info... Thanks.
Originally Posted by LakerRaider
(Post 9191415)
Originally Posted by Twism10
(Post 9303645)
Originally Posted by GraphiteEvo9
(Post 9380319)
