HELP: IS A Evo 8 5 speed Trans TB/TB Fork Same as Evo 8 6 speed?
Hey guys this might be a newbie question but i want to ask.
I have a car that im putting a evo 8 mr 6 speed trans. Perviously the 6 speed trans had a Quarter master clutch with Hydro Throwout bearing. Normally on a evo 8 5 speed trans, when adding a Hydro TB you remove the OEM TB and shifter fork for the TB. My Question is, is the 6 speed assembly for the TB the same as a 5 speed? Meaning can i take the fork/spring/rod/TB out of my 5 speed and put it into my 6 speed so i can reuse a stock TB in the 6 speed??? LMK GUYS THANks |
newbie question? no.. smart to ask? yes..... never hurts to be safe then sorry. i just cross referenced the 6 speed vs the 5 speed setup for you through my parts program and they are both the same clutch fork, throw out bearing assembly etc.. so you should be good to go.
^ Thanks a Bunch man, Saves me a big Headache :)
anytime {thumbup}
CAn some one post a picture of the Evo 8 6 speed broken down???
I need to see a pic of the Throw out bearing/ shifter fork assembly |
