Radiator doesn't suck in antifreeze..
Sorry if theres already a thread about this kind of thing i looked and a lot that i find aren't what im looking for.. so i got my car back from a shop and they said after they drove it all the antifreeze pushed out the overflow.. They said it might be the cap and put on a new one. i drove home (like 30 miles) and after i let everything cool off i check and the radiator was still dry and the overflow was just about overflowing, right to the top... any ideas? help is much appreciated.
...have you changed the cap like they suggested?...only a few bucks from autozone
They put a new one on at the shop. But when I got home there still wasn't any in the radiator. The overflow was over full doesn't suck it in..
could be a blown headgasket. could be pushing compression out of radiator.
Originally Posted by eavwidl
(Post 9331176)
could be a blown headgasket. Could be pushing compression out of radiator.
And a reputable shop would be able to test this for you with a block tester. Its a tool that plugs the radiator filler opening with a blue fluid in it. You use a small rubber suction device that pulls air from the radiator through the fluid. If it turns yellow your getting fuel fumes/exhaust in the coolant indicating a bad headgasket. Some auto parts stores sell them and you can do it yourself. Literally takes 10 - 15 minutes. Edit: If you want to do it yourself Autozone has the tool for about 25 bucks and the fluid for about 8. |
Damn that sucks. And you drove without any coolant? What kind of shop did you take your car to? They sounds like they didn't check ur car just kinda guessed then gave it back to you. Did they try to figure this out? Or did you not ask them? I'm confused why you would post here when your car was already at a shop...
I hope you get this taken care of soon before anything happens. GL dood |
Originally Posted by emo_joey
(Post 9331233)
sounds like your "speedshop" might have been doggin your car out tryin to find that whistlin noise. just my 2 cents.if it didint happen before and now it is i say its there fault
Yeah that's why I hate bringing it places.
Originally Posted by EAVWIDL
(Post 9331176)
First, the only time coolant is pulled from the jug is when there is vacuum in the cooling system. This occurs as the engine cools, not when driven and only if the system is tight. Second, it sounds like the shop lifted the head while testing.
Originally Posted by barneyb
(Post 9331857)
hope you can prove it was the shops fault.. you may need to speak with who test drove the car. |
(Post 9331857)
Read my other post and you will be able to see the status of the headgasket for like 35-40 bucks.
Originally Posted by evo 9 guy
(Post 9331993)
| All times are GMT -7. The time now is 02:18 PM. |
